Results 1 to 5 of 5
    Apr 2011
    AZ
    Bravo 1 versus TRS, which will handle more power
    I want to know if the Bravo 1 versus the TRS outdrive would be better for a BBC application. Does anyone know what the power rating is for the Bravo 1 and also for the TRS outdrives? I am looking for the torque rating of each outdrive.
    I am restoring a 1977 Hallet that came with a TRS outdrive, 454BBC, and Merctrans transmission. I like the idea of having a transmission doing the shifting instead of doing it in the lower unit. I have heard that the lower unit shifting can cause extra stess on the gears that can lead to gear breakage in a Bravo 1.
    I have a Bravo 1 outdrive that I can substitue for the TRS outdrive if the Bravo 1 has a higher torque rating with the possibility of lasting longer than the TRS.
    Anyone with real world experience pros and cons?
    Thanks for any help you can provide.
    Bravo by far, the transmissions break just as easily( or easier) as the Bravos. Parts for TRS and especially the merc trannies are hard to come by now and they are heavy. Between Max Machine Works ,Teauge and IMCO a Bravo can be upgraded to be nearly bullet proof.
    Feb 2003
    St. Pete Bch., FL
    if no one else responds i'd call craig colabella @ collabella performance. no one knows more about merc lower units/drives than him IMHO (407) 498-0094
    96' STV Euro
    Smarta$$ of the
    Sunshine Syndicate,
    How to upload pics (click here)
    Quote Originally Posted by jphii View Post
    Well then, give her a $50 bottle of booze and don't let her know about the hookers, or what you spend on them
    Quote Originally Posted by 1BadAction View Post
    oh no. i just realized I am the voice of reason on a thread. i am so done, RIP 1Bad.
    I see IMCO is making a surface drive version now.
    Apr 2011
    AZ
    Does anyone have the actual torque rating specifications for the Bravo1 and for the TRS?
Eddie Marine - Horizontal
