Results 1 to 6 of 6
Thread: Paint doesn't look right?
05-14-2011, 02:24 PM #1Member
- Sep 2002
- harrisburg pa
- 50
I painted an old 140 Johnson cowling with Pettit marine paint, Easypoxy, single componet polyurethane. Prep work was fine but first cost had a slight orange peel look. I did a light sanding and painted again. Paint looks good a few feet away but up close I can see the slight orange peel look. Called mfg and they said to wait 30 days and polish it. Is this the typical way to get a factory looking finish or am I doing something wrong. Thanks in advance
05-14-2011, 02:41 PM #25000 RPM
- Feb 2003
- Chicago
- 756
- 10
did you reduce with spraying thinner 10%,or you could of sprayed to far away.wet sand 1000 grit and buff
THE BEST PART OF LIFE IS SPENT ON THE WATER
05-14-2011, 03:43 PM #3Member
- Sep 2002
- harrisburg pa
- 50
Thanks yachter55. I did use thinner per instructions and maybe I was to far away. Any recomendation what polish to use.
05-14-2011, 05:08 PM #47000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
It happens, most paint jobs are not 100% until there sanded and buffed.
05-14-2011, 07:59 PM #55000 RPM
- Feb 2003
- Chicago
- 756
- 10
any scratch or swirl mark remover, no heavy compound,and no wax for a month
09-18-2011, 07:55 PM #6
Air pressure too high?
