Results 1 to 12 of 12
05-06-2011, 10:57 AM #1Member
- Jan 2010
- eatonton ga
- 36
need help with omc optical ignition
got a 90 hp with the omc optical ignition it will crank and run but going down the lake it is losing fire like you cut the key off and on is there any way to check ignition without the omc tester and what would be the most likly cause thanks for any help
05-06-2011, 11:05 AM #2
05-06-2011, 07:41 PM #3
You didn't change plugs or wires did you? The wrong ones will screw things up!
05-08-2011, 03:28 PM #4
So it starts fine cold, and then quits running once the engine warms up? That sounds alot like the issue I had with a power pack, I lost spark on the port bank. Usually it would crank and go the the first fishing hole, then you were done for a while.
I bought the OMC tester off Ebay or BBC, I can't remember, it's way better then guessing.
05-10-2011, 11:59 AM #5Member
- Jan 2010
- eatonton ga
- 36
thanks for the replys it has the right plugs and original wires im gonna try the sensor first the pack is $300
05-10-2011, 07:09 PM #6
the sensor is a go-no go thing, usually this sort of problem is a bad stator, pack, wiring or ground.........
05-10-2011, 09:19 PM #7
If you need a pack, you can do better then 300, I didn't pay that much for mine, and i got a new BRP one. Try bestboatparts.com . A good shop manual and a voltmeter will help you. I bought the tester because its just a plug and play deal.
05-11-2011, 07:52 AM #85000 RPM
- Jul 2007
- Ms. gulf Coast
- 334
is the engine actually die-ing or just an on/off/on, or just loosing power ?
05-11-2011, 12:09 PM #9Member
- Jan 2010
- eatonton ga
- 36
its not dieing its surging if it was an old crossflow i would already put a pack on it just not sure on the optical ignition ordered the eye tryin it first if not gonna replace the pack thanks for the help
05-11-2011, 09:15 PM #105000 RPM
- Jul 2007
- Ms. gulf Coast
- 334
ive got 2 complete ign systems for the 60 deg v4's, 96 and 01, but your problem sounds like the power pack, do a stator voltage output test first, if ok its prolly the pack.
05-11-2011, 09:55 PM #11
05-18-2011, 08:26 AM #12Member
- Jan 2010
- eatonton ga
- 36
thanks for all the help tried the eye first then the pack pack fixed it thanks agin for all the help
