Page 6 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 76 to 90 of 104
  1. #76
    Mar 2009
    Port Saint Lucie
    Were your carbs rejetted rich, or stock it was rich? You always run 93 in your motor?
  2. #77
    hes got a monty motor so im sure monty took care of the jetting before hand
  3. #78
    Mar 2009
    Port Saint Lucie
    I called monty today, he didnt answer. I'll call him next week to talk about jetting.
  4. #79
    Jan 2005
    Fort Lauderdale
    Quote Originally Posted by Gorilla0178 View Post
    hing
    Before I bought my motor it had originally sunk under water. Barney from Action took the motor to Monty to repair everything that was damaged. While it was at his shop, he "cleaned up" the exhaust ports and re-jetted the carbs because the motor was going to be used strictly for pleasure boating. In other words, it was set up to be as reliable as possible. When I bought the motor it had 95-100 psi on all 6 cylinders. After a few years of using it like that, I bumped the compression up a few notches. Much better hole-shot and mid-range punch. I always run 93 in the boat now. I would occasionally run 89 before the compression bump but not anymore. I did blow my powerhead up once before I got the heads done but that was due to a restriction in one of the carbs. Since then, I have had zero issues with the block/rotating assembly. I have replaced the powerpack and one of the coils though. Not bad for over 7 years of abuse.
  5. #80
    Mar 2009
    Port Saint Lucie
    When you put the 2.7 heads on, do you plumb the thermostats like the older motor, or the same
    as the newer motor. The older motor has the poppet valves incorporated with the thermostats. The newer style has the poppet valve in-between the thermostats. The older motor is plumbed from
    the port stat, to the stbd stat, then it dumps out the bottom of the cowling. My motor has the
    stats plumbed into the poppet valve. I can block off my poppet valve if it doesn't need to be used.
  6. #81
    Mar 2009
    Port Saint Lucie
    Dave do you know what jets your running?
  7. #82
    Jan 2005
    Fort Lauderdale
    I'm not sure, I haven't pulled my mains out since I popped the motor years ago. I've got the boat stored at a family member's house until I move into my new place on the 11th. Once I get the boat back, I can check for you.
  8. #83
    Mar 2009
    Port Saint Lucie
    No prob, no rush, was wondering as a reference.
  9. #84
    Mar 2009
    Port Saint Lucie
    Anybody?
  10. #85
    Jul 2009
    savannah,ga.
    Just picked up 2.7 heads myself for a '98 225. I'm running 72D jets now, which are stock for this motor. The only stock size I am aware of that's bigger is 74D's, for the 250HP. Is that enough, or do I need something bigger? I assume you're not talking about the midrange jets, as going bigger would make it leaner.
  11. #86
    Mar 2009
    Port Saint Lucie
    No it's the high speed jets. In my motor they are 67d which are stock. If you read this entire
    thread there are varying opinions on jetting, some say go up one for every 10 psi, there is a post
    that says he never rejetted and has never had a problem. So I don't know. Some say you have to
    run mid or premium gas, which is better any ways. My plan is to put them on and see where I'm
    at with jetting. I've been told my motor is running rich as it is, it's on a small lite boat, where as it is meant to go on a much heavier boat. We'll see how it goes.
  12. #87
    Jul 2009
    savannah,ga.
    I'm running mine on a '79 Viking at 675lbs. dry. I just looked, and found bigger jets, but I'm pretty sure I'm running kind of rich now. Do you know where the idle relief ports are located?Any diagrams, or is it right in your face when you pull the head and the piston is on the downstroke?
  13. #88
    Jun 2002
    Winter Haven Fl.
    Idle reliefs are little holes right over the exhaust ports that just bleed off compression at idle.
  14. #89
    Jul 2009
    savannah,ga.
    Quote Originally Posted by oldschoolltv View Post
    I just talked to Will Gross at Premier Marine, in Orlando. He says he can do the cooling mod for $150 if I strip the block. He says some work has to be done inside. What is your experience with this? I have a '98 powerhead. I really don't want to pull the block apart just to use these heads unless absolutely necessary. Thanks for the info on the reliefs!
  15. #90
    Mar 2009
    Port Saint Lucie
    I don't know what the cooling mod intails, I'm not planning on doing it. I've heard it's not a
    necessity. But I'm not real sure. Keep posted with what you find out.
