Results 1 to 15 of 41
Thread: Anyone see a problem here?
04-25-2011, 05:58 PM #1
<iframe title="YouTube video player" width="640" height="510" src="http://www.youtube.com/embed/Zfx6l8q3lSw" frameborder="0" allowfullscreen></iframe>
Come to your own conclusions.........
04-25-2011, 05:59 PM #2
<iframe title="YouTube video player" width="640" height="510" src="http://www.youtube.com/embed/sV3ZoYscXVM" frameborder="0" allowfullscreen></iframe>
04-25-2011, 06:00 PM #3
MERCURY RESPONSE -
We have reviewed the records documented at Mercury Marine along with the video clips provided by you. There is no evidence of a product defect.
We are unable to provide your request for uncut cowls as Mercury Marine does not manufacture and/or test such a modification to our product. This limited warranty does not cover operation of the product in a manner inconsistent with the recommended operation/duty cycle section of the Operation and Maintenance Manual, alteration of parts.
We have receive and reviewed your understanding regarding our warranty limitations. We now consider this issue closed.
04-25-2011, 06:04 PM #4
Hmmmmm, the ability to SUCK IN WATER doesn't strike MERCURY RACING as a product defect. Below is a scenario I stated to Mercury when bringing this issue up.
Take in consideration this scenario : A guy with his wife and two kids are coming back from a fishing trip offshore of Florida. A quick rain storm pops
up a few miles from the inlet. Not a big deal, he has driven in the rain before and his electronics keep him on track. He gets to the entrance of the inlet
and the tide in is ripping out. As he gets halfway through the rough inlet, his TPS sensor malfunctions because it got wet from the wind and rain and throws a fault code to the motor. Boat loses power and is now getting swept towards the rocks. Tide is way too strong to power out of it with only " idle power". Before he has a chance for a distress call, the boat is smashed up on the rocks, wife and kids are thrown in the water only to be crushed by dads boat which was powered by a 300xs. An investigation finds that during these last few minutes, the motor recorded a fault in the TPS. Which in turn reduces power. Enough to even stall the motor. A motor that has had reported problems of ingesting water a fouling TPS sensors. Mercury is found liable and a 50 million dollar settlement is handed out.
04-25-2011, 06:06 PM #5
I'm thinking there is vacuum comming off the back of the cowling
pulling the water up? How about some of those cavitation plate extensions
to minimize the prop spray.Formula 260ss 496HO
Bender Clan Member
04-25-2011, 06:10 PM #6
I can't say I really have a dog in this fight as I sold my boat however, I feel that anyone thinking about purchasing a Mercury should be aware. I know some of you have seen me idling back to the ramp because of a wet TPS... not fun. Even if this post prompts Merc to look into the issue
and re-design the cowling I have done someone good. I asked Mercury to send me two " Un-cut " cowlings. One for me and one for the gentleman who purchased my motor....below is the response to that
MERCURY RACING- We are unable to provide your request for uncut cowls as Mercury Marine does not manufacture and/or test such a modification to our product. This limited warranty does not cover operation of the product in a manner inconsistent with the recommended operation/duty cycle section of the Operation and Maintenance Manual, alteration of parts.
04-25-2011, 06:11 PM #7
Clockwork, does the inside of the cowl have a water shield? I thought they did, so if you trim up all the way when boat is parked, water that comes in the rear port runs down to the pan's drain hole....
Jr.Larry Gempp Jr.
04-25-2011, 06:16 PM #8
Regardless of any " devices " or additions made to the boat or motor, NO motor should easily be able to accomplish this. ( my fix was a zip-loc taped around the TPS ) What about guys who run in salt water..... what do their power-heads look like. Or even better, the inside ? Salt deposits on bearing surfaces, rings, cylinder walls?
04-25-2011, 06:18 PM #9
NO water shield- Water comes in through the vent and dumped down both sides of the motor AND obviously sucked into the intake.It had sound insulation inside the cowl, I removed it from HOLDING water ( did not make a noticeable sound diff.)
04-25-2011, 07:03 PM #10
A buddy from the Keys had a water dump shield made by a local fabricator in the Big Pine area that basically screwed on to the back of the lower cowl where the water dump is and directed water back and down . He had the same problem and I agree it should be standard equipment as a low pressure area will exist at the back of the engine .It was an inverted " U " shaped channel welded to a small plate that fastened on with two screws and presumably some type of RTV . Solved his problem .
04-25-2011, 07:09 PM #11
That is a typical response from Mercury. The ol' "There is not a problem even though there is, and no we will not work with you to fix it because there is not a problem." At least with BRP there is some intelligence on the end of the phone line.
04-25-2011, 08:13 PM #12
If mercury admits a defect then they would have to fix all of them?? Wouldn't a easy fix be a water-proof TPS?
90 21Skater w/300xs - sold
98 STV Euroski w/280 - sold
04-25-2011, 08:28 PM #13
04-25-2011, 08:30 PM #14
04-25-2011, 08:31 PM #155000 RPM
- Jan 2004
- Lindenhurst, NY
- 658
- 87
- 64
- 3359
- 267
I have seen this on a 32 Skater, when the boat came back out of the water, the engine was covered with salt water inside the cowl.
