Results 16 to 30 of 31
07-11-2011, 02:37 PM #16
Spike,
I am a big fan of Olds 455's and agree with you that you can make them live and if properly set up they can make good HP.
My problem I have with one of my Olds motors, wants me to make an anchor out of it.
I have thrown big $$ at it, done all the mods and imported the best parts I could find.
The same journal gets thrashed every time. I have rebuild the motor a total of 4 times and the same journal (No5) gets beat to sh#t. New crank every time (used), new I beam rods, clearances as per Mondello's and Bill Trovato etc.
Do you maybe have any suggestions.
Sorry for hi-jacking your thread Gerfguy, but maybe it is something that we are missing and can help.
Wikus
07-18-2011, 04:26 PM #17Junior Member
- Jun 2008
- Waucanda, IL
- 20
Cam selection should be based on load, maximum RPM expected and power goals, not how it sounds at idle. In a marine application, exhaust plays a big part as well- If you have logs that dump out the transom and under the water, you need to me more concerned with reversion than if you have over the transom exhaust.
My CVX-20 was running the popular Comp Cams hydraulic 455 Olds 'Perfect for Jet Boat' cam but with the exhaust under the water, I had a horrible time with exhaust reversion at idle/low speed.
It would suck in the rubber flappers just sitting at idle in the water- Not good.
I ended up with a custom cam that that has minimal overlap and fits my power requirements nicely.
There are a lot of choices out there- Just make sure you go with what you need for your application and not for how it sounds idle. Most of your boating isn't done at idle anyway-
Just my 2 cents.
Elm
07-23-2011, 05:10 AM #18Junior Member
- Jul 2011
- Amarillo
10-13-2011, 01:05 AM #195000 RPM
- Oct 2007
- Los Angeles
- 133
Wilkus,
Oh my, four times #5 beats itself to death! I can't really say, over the phone, so to speak. But, if you use a different crank every time, and use a different rod every time, and have no problems elsewhere, at very least, you know where to concentrate your search.
I was thinking about the problem....if you rule out clearances, poor components or machining, as you indicate, what about this...................your firing order is 18436572. This is a longshot, but could your ignition be a factor? Because #6 fires just before #5, if it crossfires in the cap, or induces a pulse thru the wires to #5, that #5 cylinder can fire too soon, hammering the piston and bearings and rod. Any spark plug damage to #5 plug as well? Something to think about. Maybe not an issue. It's the only weird outside thing I could think of, save for actually tearing the damaged engine down for a more educated report.
10-13-2011, 02:30 AM #20
Spike,
Thank you for the reply, it is something I will definitely look into. I busy assembling the motor as we speak. I have gone with Eagle H-Beam rods this time, Cryo Treated Clevite bearings and was at the machine shop, checking the machinists work as he was grinding the crank etc.
New block which was magnafluxed and all the oil galleys checked. If this doesn't work I am going to import a sub assembly from either Mondello or Bill Trovato. I am stuck on the Olds and just loves the way they look and sound.
Wiikus
10-13-2011, 04:43 AM #21
do you guys ever use the msd ignition so you could use say a 5000 or even 4700 rev limiter and use an impellor that will be pushing hard at that rpm? i had several olds 442's growing up and they were so awesome, and so much torque. stock, they ran out of power at about 4700 and if you didnt shift, they just quit pulling. im talking about 68 and 69. after 71, no compression just killed even the 455 w-30. my father had one
90 Vegas 89 200 78mph
10-13-2011, 09:57 PM #225000 RPM
- Oct 2007
- Los Angeles
- 133
Wiikus,
Keep on keepin' on with that big Olds. I've read many things about Cryo-treating engine parts, and I want to endulge in it myself on some current projects. Come back on here to let us know how things turn out for you.
Personally, I think engines are a lot of fun.....it's all about the engine when it comes to a performance boat, otherwise, all you have is a fancy canoe! Hey! Good boat name......"Fancy Canoe"
10-14-2011, 12:57 AM #235000 RPM
- Jul 2007
- Ms. gulf Coast
- 334
10-15-2011, 01:05 AM #245000 RPM
- Oct 2007
- Los Angeles
- 133
IF , and this can happen, but If you crossfire in the cap, it may be caused by a hairline crack in the cap between the two electrodes, or it can happen if there is a carbon trail allowing an arc to jump between the terminals in the cap. In either case, I believe you should be able to see either with the naked eye by inspecting the distributor cap real good. Sometimes, even bad spark plug wire boots side-by-side can spark across to each other. You can see this kind of stuff when you put a car on an oscilloscope to tune it, but when was the last time you've seen one used, and boat shops may not even have one. Sometimes, an ignition is updated to a capacitive discharge style box for a hotter spark, going through a stock distributor and factory style plug wires, and the voltage is too much for the cap or wires. The obvious fix is to upgrade the cap and wires to a heavier insulated dielectric cap, and heavier insulated ( larger diameter ) wires.
Check out photos of drag cars and boats from the sixties, all running hot magnetos. Those mags put out way more zap than a stock battery ignition and most used 7mm Delco wire core plug wires, and put out lots of horsepower even under heavy fuel loads and boost, without crossfiring, but things were starting to change.
Then the seventies come in, and for smog reasons, cars are tuned to run lean, and start to misfire, so the factorys begin to go electronic, with Lean-Burn, H.E.I., etc, and now, spark plug wiring begins to get heavier insulated with 8mm wires to contain the higher voltage potential. Hot rodders were starting to use the new ignitions over the old "dual-point" set-ups.
Today, we can run really hot ignitions that are breakerless, and capacitive discharge, such as the popular MSD line. ( Personally, I prefer the simplicity and reliability of a scintilla vertex , or Schiefer/Cirello magneto on my projects ). Plug wiring can be 9mm or larger to contain the voltage. Big wires don't make any more power, they just are necessary only when your ignition requires it, such as high voltage. ( It's like the old saying, "..if your car doesn't ping running regular gas, using super won't make any more power"), so if your engine runs good using 7mm wires, 9mm wires won't make it run any better.
Bottom line, if you're crossfiring in the cap ,or inducing voltage through your plug wires,,,,#1- get a new cap and wire set, #2 -separate your plug wires away from each other with looms running all the way from the cap to each plug, and #3- if your ignition has been upgraded, get an even heavier cap and better wires. Again, this all may be a longshot as to the #5 bearing pounding, but it could happen. Ford recognised the possibility of inductive crossfiring in their 15426378 firing order, with 7 and 8 being the likely culprits, and separate 7 and 8 wire at the loom on the left valve cover by placing the wires at opposite ends through the loom from the factory on their V-8s. Now, lots of Ford guys will loom their left side wires 5678 front to back just like the cylinders are, and never have a problem, but even with a stock point and coil ignition, Ford engineers knew it could induce a misfire under the right conditions, so they separated the wires in the loom. It's in the Factory shop manuals. It's, less likely in GM's 6-5 firing, being that the cyls are on opposite sides of the engine, making it more likely to be in the cap, and for most people, this never happens, but it could where any two cylinders sucessively fire. Anyway, it's food for thought, and easy and cheap to remedy.Last edited by Spike Morelli; 10-15-2011 at 01:56 AM.
11-06-2011, 09:50 PM #255000 RPM
- Oct 2007
- Los Angeles
- 133
Gerfguy,
Yes, we always ran high test. Everybody did, that had a hot boat back in the 60's/70's, but today may be a different story because of the lower octane gas available.
I don't know at what comp regular unleaded is good up to. Because of all of the variables in each engine, such as head chamber shape, ignition timing, engine temp, cam overlap bleed-off, etc, it's a matter of having used a certain combination with good success, but 9 to 1 is safe usually, some combinations can run a little more. With today's better manifolding, ignitions, cams, and such, many engine builders are getting big power from 9 to 1 comp engines, than we got in the sixties.
11-14-2011, 12:58 AM #265000 RPM
- Oct 2007
- Los Angeles
- 133
11-26-2011, 02:22 AM #27Junior Member
- May 2004
- 9
for cap and rotor use brass components, aluminum breaksdown and promotes crossfire on loaded engines. saw lots of SBC kill offshore raceboat engines in key west back in early 80's, plugwires would just be tied together and laying on manifolds. salt spray contributes also.
11-29-2011, 03:50 PM #28
Spike,
I finally got the motor assembled and had the first test fire today. I took my time collecting and importing the parts on this one and it was well worth it. I must say she sounds damn sweet. Oil pressure cold is @ 80Psi and drops down to 60Psi, temp is 180 degrees F @ 15Psi in the block. Had to run in the new cam (292 Iskey from Duane (HTP). The 10Qt oil pan is also a huge improvement from the 8Qt I previously ran. Next is installing the drive shaft and then off to the lake. Will post some pics when I get a chance, had some stuff done to the hull as well.
My boat's name is "Prawn Star" my nickname - my name is Wikus like the character in District 9 (Wikus van der Merwe) who calls the aliens "F#cking Prawns" my friends thought it appropriate.
WikusLast edited by Hamjet; 11-29-2011 at 04:09 PM.
12-07-2011, 12:07 AM #29Banned
- Nov 2010
- united states
- 47
Cut your losses sooner then later and get chevy.You will be money ahead in the long run.Or you can dump a few more thousand into and wish ths whole time you had cut your losses sooner.
12-07-2011, 04:48 PM #30
