Results 1 to 5 of 5
03-30-2011, 07:57 PM #1
8 HP LOWER UNIT REMOVAL, 1997 Mercury
I was given a 1997 Mercury 8 HP long shaft motor and I can't seem to get the lower unit off. There are only three bolts that hold the lower unit on. I removed those and I can pull the lower unit down about three inches and it won't come off any further. What am I missing.
Thanks, Carter Powell
03-30-2011, 11:15 PM #25000 RPM
- Jun 2009
- central minnesota
- 770
- 30
- 24
shift shaft-must disconnect under carb aera
03-31-2011, 07:32 PM #35000 RPM
- Aug 2007
- Gravenhurst, Ontario.
- 708
- 50
- 42
- 199
- 210
05-07-2011, 02:41 PM #4
How did you ever make out with this lower unit. I have a 8hp that I cannot get the lower unit off. I was cleaning carb and while I had that off I unhooked shift shaft under the carb and still won't drop out through midsection.
05-07-2011, 05:44 PM #5
You also need to remove sm clamp half way down midsection that allows motor to kick up or not!!!!! I t clamps around shift shaft.
