Results 1 to 15 of 15
11-12-2002, 10:51 PM #1
8-new High Tech, High Performance Prototype Props!!!
NOT AVALIABLE IN STORES. (YET)
11-12-2002, 10:53 PM #2
i only counted 4
77 vector 77 1500xs merc ,16 ft comp laser
18ft wellcraft kona v6 mariner ........ There is nothing more satisfying than speed. Speed is addictive, remember you can only go faster.
11-12-2002, 10:55 PM #3
THE OTHER 4
THESE ARE THE SALAD-SHOOTER-SERIES.
Thats right, They Dice, Slice,and make Jeuleon fries!
Place your order now and receive a free set of Ginsu Carving Knives!Last edited by RULE-1; 11-13-2002 at 12:16 AM.
11-12-2002, 11:01 PM #4
maybe i can weld a hub to a circular saw blade & save money
11-12-2002, 11:10 PM #5
Looks like they'd take care of the manatee problem even at 30 mph! Where do I sign up for one?
11-12-2002, 11:15 PM #6
wow they would do some damage in the indian river
or the inner coastal77 vector 77 1500xs merc ,16 ft comp laser
11-12-2002, 11:29 PM #7
I'LL BE TAKING ORDERS SOON!
but with the increased speeds, you will first have to outfit your rig with a Parashoot, and Oxygen mask.
Here is" Warp 5"
LOOK OUT WARREN, I'M COMING BY YOU THIS TIME!Last edited by RULE-1; 11-13-2002 at 12:20 AM.
11-13-2002, 01:19 AM #8
The government worked on that years ago. Problem is you start cutting the water so fast, it separates the hydrogen and oxygen atoms and then you get into the whole instantainous combustion thing. You know, cold fusion stuff. You sure as hell don't want that going on behind your boat do you? You would burn up all the water in the lake and where would the rest of us be?
"As government expands, liberty contracts." -Ronald Reagan
Liberty = boating
11-13-2002, 01:29 AM #9
Thats the name...
of my pops boat "Cold Fusion". 1939 Greavette Streamliner made up here in Canada. Beutiful 22 foot mahoganey boat shaped like a cigar. Really cool. Ill try to get pics, not the fastest, but a beautiful ride.
11-13-2002, 02:02 AM #10
Hehehehe
now dats funny !!GOT THE NEED FOR SPEED !!
OMC-ya
11-13-2002, 07:14 AM #11
Das a beutiful!!!!
11-13-2002, 09:44 AM #12
Rule-1
I believe that prop in the upper right hand corner is the one I tried and sent back.
It grabbed at first then slipped really bad
-BL
11-13-2002, 09:51 AM #13
Who's making those props ?
Moulinex. They chop, slice and dice and if you order now.................., we'll include the BIG NUT prop nut
Sean, 19 J-Craft ,225 Johnson
If everything seems to be going well,you have obviously overlooked something
11-13-2002, 09:55 AM #14
Top right--
Well that's the weedless prop; you have to be running it through weeds to make it work right. It was slipping cause you didn't have enough weeds.
I want one of those, I think if you file it real sharp you might be able to run the boat right up on shore. Then I could eliminate that pain-in-the-ars dock for once and all!"As government expands, liberty contracts." -Ronald Reagan
Liberty = boating
11-13-2002, 02:21 PM #15
I believe
those are the blades for the " BASS-O- MATIC"
Crew chief 2004 CHAMP ROOKIE OF THE YEAR!!!
