Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
    Jul 2009
    new iberia, la
    Where did you buy it from? Ive been checking online and the cheapest I can find the HK7400 Pro kit with hoses is $850 shipped from lowcostboatingstore.com
  2. #17
    Jul 2009
    MIA, Florida
    That sounds about right. You can also find the complete kits that include the Pro kevlar hoses HK73XX (XX is the feet of hose, for example HK7318 has 18 foot hoses).
    I ended up ordering locally and got the entire Pro setup seperately with the 6345 Pro cylinder (not the kit that comes with non-pro 5345 cylinder). Ended up costing me about 200 more than the kit price, I got the Pro helm/ Pro cylinder/Pro 18ft lines/ and 2 quarts of oil.
  3. #18
    Jul 2004
    Connecticut
    What distributor would you say is the most knowledgeable on the Teleflex stuff ?
  4. #19
    Jul 2009
    MIA, Florida
    Try Wildman on the forum...I think he carries Seastar.
  5. #20
    Jan 2005
    florence s.c.
    Sea Star Pro
    I think the pro is more suited for a V bottom cause of quicker response... May be wrong...
  6. #21
    Feb 2011
    HUDSON, FLORIDA
    why does fluid immediatly come out when i loosen my pro helm fill cap? i can move my wheel a ram doesnt move? 1'' + -.each direction?
  7. #22
    NE Louisiana
    Quote Originally Posted by KIRCHNER View Post
    Cycle it from one end to the other several times. It will work the air into the helm eventually. Other wise you may just need to bleed it. I always reused the oil I pumped out.
    Again, as far as the keyed cylinder, hype and sales gimmick. If you install it correctly, it will bind as it is a tapered fit. If you torque the hardware correctly and use the correct spacers, you should have no problems.
    As far as the leaking end caps, that can be solved by a visit to your local hydraulic shop to buy $10 worth of O rings... Unless you are just a lazy sloth and prefer to buy all new stuff.
    Those that know what works, know. Those that do not will remain ignorant I guess.
    SeaStar Pro, Kevlar hoses, stock cylinder.
  8. Thanks pcrussell50 thanked for this post
    Likes rgsauger, pcrussell50 liked this post
  9. #23
    I have four boats, the only thing that’s the the exact same on all of them is the steering. Just like forkin said....teleflex pro gets it done very well.
  10. Thanks pcrussell50 thanked for this post
    Likes pcrussell50, Forkin' Crazy liked this post
