Results 16 to 30 of 34
02-16-2011, 09:24 AM #16
I did , nothing there
02-16-2011, 09:26 AM #17
look now.
02-16-2011, 10:35 PM #187000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
Broward bolt in pompano, on powerline road.
02-17-2011, 02:20 AM #19
Thanks
02-17-2011, 05:57 PM #20
9/16 stainless
I hade mine made at local machine shop. Are u using cmc jackplates?
02-18-2011, 12:07 AM #21
CMC stainless plates
02-18-2011, 11:12 AM #22
Yeah Cmc drills there 5.5 jackplates 9/16 for some reason?
I pulled mine last year because the 1/2 bolts were letting my motors pull together. from turning my props in.
I bought the 9/16 stainless dowel and had them thread and weld a nut and washer on one end and thread the other. I would not use threaded rod.
I had a few extra made. I will see if i cant get you a pic.
02-18-2011, 11:32 AM #23
what you had made , fine thread or course ?
02-18-2011, 07:27 PM #246000 RPM
- Calgary, Alberta
- 1,123
- 21
- 58
- 341
- 174
How about going with a stronger grade of stainless like 17-4 preciptation hardening (PH) instead of more typical 18-8 or 300 series, I bet you can find the bolts you want in coarse thread.
Matt
02-18-2011, 07:31 PM #25
Thanks , I will look into it if they dont cost more than the engines
02-18-2011, 08:03 PM #26
Unsubscribed
02-18-2011, 10:03 PM #27
04-07-2011, 04:42 PM #285000 RPM
- Nov 2003
- Gilroy, California
- 124
Hunt and Ye Shall Find What You Want!
Go to www.pointe-products.com, in the search box select Bolts & Cap Screws, click on Bolts & Cap Screws, click on Hex Cap Screws Grade 8 (SAE) Fine thread, scroll almost to the end selecting item 06-15292, and there you will see 9/16"-18 X 5 1/2" Grade 8 Hex Head Cap Screw, $16.43 each. They also have a 6" version for $17.84 if you're not sure about the length. Ironically the fine thread nuts are available at most hardware stores.
Hope this helps.
04-08-2011, 01:59 PM #29
Thanks ! But I need stainless
04-12-2011, 01:03 PM #30
I'd suspect a Grade 8 coated bolt would work fine, even in salt. I would not hesitate to use it as opposed to SS.
Keith-
