Results 1 to 7 of 7
02-06-2011, 04:33 PM #15000 RPM
- Jun 2006
- Ramona Ca
- 270
What causes to much water pressure on a 2.5 200 efi?
I am getting around 30psi on the water pressure gauge. I have been told that this is way high. What would cause this? Thanks Mike
02-06-2011, 05:16 PM #2
poppit possibly not opening, clog in water jacket, guage wrong. Some things to look at.
02-06-2011, 10:15 PM #3
Head gasket,been there done that!
1976 Hydrostream Vector/Merc 200/2.4 sold
1977 Hydrostream Ventura Comp. 2.5 sold
1985 Action/Motion 15" Cherry 2.4
02-06-2011, 11:35 PM #4Supporting Vendor
- 11,838
- 163
- 11
- 795
Several ways for too much water pressure...
1. Poppet issues
2. Restriction of spent water leaving the block ( pebbles , wood, dried aquatic material in block or cross over area at divider plate )
3. Head gasket ( If your water pressure is pulsing and pegging your gauge high pressure compression is entering the low pressure water system )
Good luck,
Jay
Jay @ JSRE
02-07-2011, 08:02 PM #5Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Where the water goes out of the poppet and into the mid there is a small hole that can be cloged by a perriwinkel....small shelled salt water critter. Had them jam shift locks too......I have seen salt dry and clog the poppet to..... but not on latter motors that have water piped to the outter side of the poppet.
02-11-2011, 12:09 AM #65000 RPM
- Jun 2006
- Ramona Ca
- 270
Would the compression be low if it is the head gasket?
02-11-2011, 12:01 PM #7Supporting Vendor
- 11,838
- 163
- 11
- 795
Yes the suspect hole would be down considerable in cranking compression...
Jay
Jay @ JSRE
