Results 1 to 7 of 7
Thread: Berkeley Jet Rebuilding Tools
01-23-2011, 02:27 PM #1Junior Member
- Jun 2008
- Waucanda, IL
- 20
I know this is a long shot but it doesn't hurt to ask-
I'm looking if anyone has any used Berkeley Jet tools to sell.
I know they are available new but $125 for a puller or $350 for the set is a bit steep for one time use.
I'm mainly interested in the impeller puller but would be interested in the others as well.
Thanks!
Elm
02-03-2011, 11:06 AM #25000 RPM
- Mar 2009
- TENN
- 211
if you are wanting one time use, give me a call, pay refundable deposit, and will loan you a set of what u need. 423-745-9667, johnny
02-03-2011, 02:09 PM #3Junior Member
- Jun 2008
- Waucanda, IL
- 20
John,
Thank you for the offer.
Berkeley / CPPerformance rent tools as well but I would like to assemble a set to own in case I ever need to get back in and repair/replace something down the road.
Shipping tools back and forth across the country is my last resort but I may need to consider it.
I'll drop you a line if I decide to go that route.
Thanks!
Elm
02-10-2011, 10:38 PM #4New Member
- Feb 2011
- Fairbanks, Alaska
- 9
Just get on line and buy your self a posi-lock puller.......................Can't remember how much I paid but though it was in the 2 hundy range.
02-11-2011, 09:52 AM #55000 RPM
- Mar 2009
- TENN
- 211
the posi-lock will work, but have seen them break the impellors when they are really stuck on the shaft which has been normal to me. for same or less money buy the puller thats made for it. .02
02-11-2011, 11:02 PM #6
Once you break an impeller, your in for a real treat.......NOT
UMPBA 926 Gas Jet
02-14-2011, 02:42 PM #75000 RPM
- Mar 2009
- TENN
- 211
had a pump job in a few weeks ago , probably the hardest i ever had. pulled the impellor into and it never budged, finally after hrs of trying to cut it out with an air saw, finally resorted to using a plasma cutter to remove the impellor, and finally had to turn the shaft down in the lathe to get the hub of the impellor off. it never gave up.
