Results 1 to 7 of 7
Thread: antfouling paint removal
01-21-2011, 08:23 AM #1
What is the best way to remove antifouling paint? I was looking at the peel away that you paint on and then pressure wash off but i've never used it before. Any advice is greatly appreciated.
01-21-2011, 08:36 AM #2Screaming And Flying!
- Miami,Fl
- 6,990
- 128
- 80
- 1269
- 368
Media blasted is the best and easest. You probably have someone local check his previous work. Rick
01-21-2011, 04:28 PM #3
01-22-2011, 08:33 PM #45000 RPM
- Jul 2009
- florida
- 273
Petit makes a bottom paint remover.. I have not used it so dont no how good it works..Blasting works well but make sure they know what there doing..
01-22-2011, 10:42 PM #5
Here in NZ we either use Soda blast or scrapers. If using scrape method take the corners off the blade with a grinder. This will help stop gouges and allows you to run up against strakes. Good luck.
02-01-2011, 09:06 AM #65000 RPM
- Mar 2009
- Tulsa,Ok
- 573
Anchor paint has a stripper called Skim,and when done can be neautralized with water
03-06-2011, 09:36 PM #75000 RPM
- Mar 2007
- washington nc
- 104
I run a fiberglass shop in NC and I purchased an attachment that goes on my pressure washer that allows you to use a sand with it. This gives you the sandblasting tech without all the dust. This system works really well but you will still have to final sand and buff hull to get a factory gel finish. I have also run into having to re-gel if person sanding boat to prep for bottom paint was to heavy handed. The attachment cost around 125.00
