Results 1 to 9 of 9
Thread: Tuners
12-18-2010, 08:29 PM #1
Tuners
I have a 2000 225 promax all stock,just bought a 280 15" mid. Can I use the 280 tuner? What would be the gain if any? Or do I use the 225 tuner?
84' Vector 225 Promax/2.5 200HP SOLD
2010 Hydrostream Venom Comp/225 PM
12-18-2010, 09:03 PM #2Screaming And Flying!
- Sep 2001
- shreveport,la
- 5,706
- 118
- 85
- 773
Very little gain if any. I'd use the 280 tuner
Erik Kiser
12-18-2010, 09:23 PM #35000 RPM
- May 2010
- Pa
- 285
dont the 225 PMs come with square exhaust outlets and the 280 tuner is oval
12-19-2010, 09:08 AM #4
Can the 225pm power head be bolted on top the 280 with no mods?
12-19-2010, 11:42 AM #5
you would have to do the cooling mods if your 280 is a 1 piece adapter plate
1994 202 blazer
K&j modded 2.5
12-19-2010, 11:49 AM #6Screaming And Flying!
- Sep 2001
- shreveport,la
- 5,706
- 118
- 85
- 773
Riverboater is correct. Do a search on "cooling mods". Its been discussed 2 or 3 million times so it should be easy to find an old thread talking about it. You could narrow your search by looking at posts by US1
Erik Kiser
12-19-2010, 12:10 PM #75000 RPM
- May 2010
- Pa
- 285
to do it the rite way you would need to pull the heads and install the rubber hose in the water jackets to slow the water flow down
12-19-2010, 05:47 PM #8
Thanks for the info.Can the pro max tuner be used on the 15" mid without any mods?
12-20-2010, 08:35 AM #9Screaming And Flying!
- Springfield,La.
- 6,579
- 17
- 2 Thread(s)
Between tha 225 PM and tha 280 tuner, I would use tha 280 tuner...Tha PM tunerz ain't hitt'in on much...If ya got a 200, 2.4 bell lay'in around, use it!!!...JMO
If ya use tha 1piece plate, do tha PH tha same az tha 280...diverters, take out tha poppit, and route dump lines like tha 280....Thats az close az U kan git...Tha steel liners like sum heet, but when ya cross worlds, they won't git tha best ov both worlds...
