Results 1 to 4 of 4
    Mar 2002
    Rockford, MI
    Driveshaft (Single Upper Bearing) fit to Sporty Question...Please read/Advise
    I have a Driveshaft for sale that came out of a Torqmaster I have that the case developed a crack, so I am parting out some of it. The part # is 45-848449-2
    A person interested would like to put this shaft in a Sporty. His question is that he understands the Sporty has 2 upper bearings, and this one has one, so he is worried about it not being correct, and fitting.
    I have been told this will fit any Sporty, CLE, 200, Torqmaster case for the 2.5's.
    Is this true, and can we help put his and my mind at ease.
    Here are a couple pics.
    Thanks for any input.
    <a href="http://s247.photobucket.com/albums/gg160/G-Train21/?action=view&amp;current=IMG_0634.jpg" target="_blank"><img src="http://i247.photobucket.com/albums/gg160/G-Train21/IMG_0634.jpg" border="0" alt="Photobucket"></a>
    <a href="http://s247.photobucket.com/albums/gg160/G-Train21/?action=view&amp;current=IMG_0635.jpg" target="_blank"><img src="http://i247.photobucket.com/albums/gg160/G-Train21/IMG_0635.jpg" border="0" alt="Photobucket"></a>
    "The Flying Clamato"
    ...This ain't no Party, This ain't no Disco, this ain't no foolin around..."Talking Heads - Life During Wartime"
    The G-Train has left the station.
    SANTEE S.C.& CONWAY S.C.
    if u put in like it is will basically be like the cases ( cle and newer style ) before the extra bearing was used after (preload style lowers) and before the double bearing you can mill shaft down under the existing bearing and add the secondary bearing . just use a double bearing shaft for reference on specs.
    MITCH HARDEE 803-974-0350 --- 95 CUSTOM BASS RR STV/300drag-- 2004 STV RR/300drag---14ft fastcraft/12in/ssm--F.I. 3cyl -whittled from 300-drag --2008 FTPB STV RR( POC FACTORY BUYBACK) IRATATE A LIBERail --missspell som'um--SPONSORS --THOROUGHBREDS INC.
    Sep 2002
    Panama City Fla.
    if you'll look closely at the shaft out of the torque master I think you'll find it has a spacer or long race center below the bearing to eliminate the lower bearing. Your photo shows it.
    www.eagleoneperformance.com
    Your right
