Results 31 to 45 of 107
06-07-2011, 09:31 PM #31Banned
- Oct 2009
- cold lake
- 165
Cool, good luck. Sure is a small world.
06-22-2011, 05:08 PM #325000 RPM
- Norway
- 935
- 61
- 13
- 354
- 182
Phantom and its new 350 sci
Hi,
Good news. Engine arrived today. It was mounted this afternoon, and the rigging will be finalised by end of tomorrow. I will get some more pictures over. The 350 sci looks massive here, but its not mounted. The strange thing is that the 350 sci is only 5 inches taller than my ol Promax 300.
Cheeers, Toffen
06-23-2011, 07:48 AM #33
congrats dude!
06-23-2011, 04:32 PM #345000 RPM
- Norway
- 935
- 61
- 13
- 354
- 182
Hi,
Thanks I will go over tomorrow. They are close to be finished. The festival I am working with starts over the week end so the boat will be on water next week end. Too much other stuff to sort out really.
The Verado 350 sci has the new Poseidon HD gearcase. The proshaft has 1,25 inches dia and has 19 splines. I struggle to find the partnumber to the required Mercury Racing’s 1.25-inch solid propeller hub kit. Do you know?
Cheeers and thanks! Toffen
06-23-2011, 05:00 PM #355000 RPM
- Richmond, Corrotoman River, VA
- 257
Looking forward to a report on this. Not many setups around like this, but it is probably a first of many to come.
Checkmate 2400, Opti Pro XS powered
06-23-2011, 06:47 PM #36
I think it's 840389K06
http://mercuryperformance.com/hd-pro...-p-106802.html
06-23-2011, 06:50 PM #37Member
- Feb 2006
- 78
Flo Torq II solid Hub kit for 1.25" shaft - 840389K06
06-23-2011, 07:12 PM #38
Toffen, Looking real good Keep the pictures and updates coming!!
Tony
06-24-2011, 07:26 AM #395000 RPM
- Norway
- 935
- 61
- 13
- 354
- 182
06-24-2011, 08:14 PM #40
07-03-2011, 06:01 PM #415000 RPM
- Norway
- 935
- 61
- 13
- 354
- 182
Hi!¨
Hope you all are well.
Got the boat on water two days ago. Have not tested wot yet as I am running 4000 - 5400 rpms for the 5 first hrs.
Fist impression; very quiet, very high class performance, great punch, much more than my PM 300, ofcourse less than twin 2.5 efis, excellent on fuel. At 4,000 rpms and 48 mph the fuel consumption is 39 liters eq to 10,5 gallon per hrs. And I have only used the engine 2 hrs. That gets you 4,57 mpg!
The lower unit creates little more drag, but can be jacked high. I can run it almost run even with the bottom and still maintain 20 psi plus waterpressure. Two inches below the bottom will be good I think. Its a heavy boat. When I had a PM 300 with the same gear ratio, the cruise speed at 4,000 rms was 50-51 mph. However, that engine was heavy on fuel. Its lots of power in the engine, so I beleive the A45 Tempest 25 will be 1-2 inches too small. I will test a Hydromotive 4bl prop and a Mirage Plus too. Both labbed and 25 pitch. When I am finished with my break in I will try to get hold of a prop that likes to be run high, to offset the extra drag in the gearcase.
Cheeers, ToffenLast edited by Toffen; 07-04-2011 at 08:32 AM.
07-05-2011, 05:29 AM #425000 RPM
- Aug 2007
- DE WITT AR
- 276
I would try a P5X Hydromotive. They have a lot of lift, both bow and stern, and are designed to be run at high gearcase levels. Call Tom Bucknell at Hydromotive Props 330 425 4266. He will help you determine which prop to use. Good luck with your project.
07-07-2011, 12:57 PM #435000 RPM
- Norway
- 935
- 61
- 13
- 354
- 182
Hi!
Managed 79 mph at 6,400 rpms today on sticky water. Lots of waterpressure (30 psi), so I will play with propheight. 80-81 mph is definetly within reach. The prop I use is a A45 Tempest 25 in stock form. I will try a labbed Mirage Plus 25 pitch and a Hydromotive 4bl labbed 25 pitch this week end. Great punch in the engine. Can turn big blades.
Cheeers, ToffenLast edited by Toffen; 07-09-2011 at 04:40 AM.
07-09-2011, 04:43 AM #445000 RPM
- Norway
- 935
- 61
- 13
- 354
- 182
07-09-2011, 10:38 AM #45I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
Checkmate 16' 140 Johnson
Laser 480 (?) 21' w/GT 200
24' Sonic w/twin 250 Johnsons
