Page 20 of 33 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 LastLast
Results 286 to 300 of 491
  1. #286
    Mine are 325/50/R22 which works out to 34.8x12.8/22 but if you put a tape measure to them I dont care how you measure them even with 70psi in them they dont measure over 33. Now the rear ones are getting pretty bald
  2. #287
    5 Post(s)
    I have had the correct speedo gear brand new sitting in the glove box to fix the problem.
    Problem is, it's no longer a gear driven cable that's easy to recalibrate.
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  3. #288
    Yea nothing is simple anymore. At this rate my truck will have historic plates by the time the speedo is correct
  4. #289
    Oct 2010
    Greenwood Lake, NY
    Superlift makes a box to alter the speedo signal on the Chevy trucks. I wouldn't be surprised if that worked for you. Not you Kev. I know your truck is old school like mine.
    I was going so slow I almost crashed. - JamesGang
    1978 24 Superboat - 250 EFI
  5. #290
    May 2009
    catskill ny
    New stuff is easy to recal ... No more getting dirty in fact I can do my truck from my phone www.sct-itsx.com
    1990 hydrostream virage diamondpower280
  6. #291
    5 Post(s)
    Quote Originally Posted by ActivatedSludge View Post
    Glad it worked out for you. They are top notch in my book, really helped me out when I did a gear swap. Kurt
    Took two tries but they got it. Was frustrating as hell plugging in the first one w/no improvement especially w/it nearly drawing blood to get to it where it's buried down beside the radiator.
    Not sure I understood what they did the first time but they said they calibrated it by lying to the computer on tire size. Only thing I can figure is that was already done and they were correct that there was a faulty sensor somewhere else.
    What I did for them was feed them readings from the van Vs my hand held GPS. Math ended up showing over 17% variable but it was constant throughout the speed range.
    Now w/the van speedo at 60 it reads 59.9 GPS which is the most accurate vehicle I've ever owned.
    Brian is also writing me a letter stating the aboves effect on my odometer too. So the 110K showing is really only about 92 K. Not that a '2000 full size van is really worth anything anyhow ; )
    So in a nut shell, anybody can make a mistake. It's up to us to give them a chance to correct it which they did.
    Thanks again for the lead. Was a huge PIA from day one on my side but they didn't get involved until the very end.
  7. #292
    Grand Ledge/ Ludington,MI
    Glad it worked out for you. Vans are not the most friendly to work on, I know from experience. I have a really nice 95 Caprice wagon with the LT1 that I am going to swap out the gears to 3.42s. It should really help out the holeshot and towing, although it really does well pulling the Allison now.
    (always have to tinker with stuff until it breaks, that's how we find the limitations!)
    Take care, Kurt
    1992 Allison XTB 21 / 225 Promax
  8. #293
    St. Cloud, FL
    New FX4 F150/EB, and Velocity on the new trailer.
    1995 Allison Grand Sport
    1998 Mercury Stock 2.5-260 SS
    1990 Velocity 30' - 502's
    Go Daddy Go! Racing
  9. #294
    5 Post(s)
    Quote Originally Posted by Ziemer View Post
    Very cool. One step behind you on the trailer. Had to move the axles back. Thats done just need to add extensions to the brake hoses and bolt one fender back on.
    You going to the Cocoa race?? We already have a room booked at the southern LQ. They sponsor a boat and are planning a party and should be a good time.
    I may try and park the Sonic in the crowd and pretend ; )
  10. #295
    St. Cloud, FL
    Thanks Gary...I found this one pretty cheap and it didn't make sense to re-do the steel one. Sold that one, and between what I paid for this one and got for the old, I got about $2600 in this aluminum, with everything new except for the axles! (which are torsions)
    Not sure if we're going to Cocoa or not. We'll either be there or in Sebastian though.
    Go Daddy Go! Racing
  11. #296
    Apr 2006
    Viera (Melbourne), FL.
    Lately I've been using my wife's Lincoln Aviator with the 300HP DOHC 4.6 for longer trips. It's a really nice vehicle to tow with. It's totally stock except for the Foose Nitrous wheels with Anthracite centers to match the lower trim colors.
Name:	Aviator and Paramount.jpg
ID:	275410   Click image for larger version.
  12. #297
    Celina, Ohio
    This is what you call overkill, We did this as a joke years ago and towed my raceboat to a race in Nashville on the road trailer with my Pete. We were racing with the unlimiteds and they all had semis so we said WTF and used mine.
  13. #298
    Celina, Ohio
    Here's a couple more tow vehicles. The ZR2 did a respectable job of towing my 24' Excaliber and the powerstroke Ford mas way more than I needed for my Stream. I guess I could've matched them up a little better!
ID:	275413   Click image for larger version.
Name:	hydrostream and pu.JPG
  14. #299
    5 Post(s)
    Here's mine. Built right in St.Cloud and one of the most impressive trailers I've owned. Torsion axles, disc's both axles, all stainless hardware, solid, one piece 4" x 10" x 10' bunks, all the wiring is heat shrinked, brake lines have chafe guards where the go through the frame, etc, etc.
    Way impressed.
    Once I sell the steel trailer I should have about $500. in this one.
    And other than having to move the bunks, axles, frame cross member, fenders, bow stop, boat guides, the Sonic fit right on ; )
  15. #300
    St. Cloud, FL
    Way impressed.
    Nice! I had mine out last week and was really happy with how it loaded. Just like you, mine fit great other than having to adjust everything. Haha...
    Ameritrail makes a nice trailer. They've done some work for me over the years. I priced a new one from them and it was about $8k for a tandem 6k lb axles, brakes, etc...
    Go Daddy Go! Racing
