Page 7 of 7 FirstFirst 1 2 3 4 5 6 7
Results 91 to 98 of 98
  1. #91
    Jul 2014
    Friday Harbor, wa
    The hose length is a good question. Adels not mounted yet. They might not be needed at all. Once I get the jackplate on I will decide on final length.
  2. #92
    East Wallyworld Vt
    Ahh yes, when I put my Magoo glasses on I see there is no screw holding the clamps, good I do not have to feel bad because they were upside down.
    On mine after four years of use the pipe thread on the elbow in the LU loosened a bit and my last outing the hose got down into the water at speed. This restricted waterflow to the pump. No damage was done, I had run a few minutes before seeing the low pressure. But I have now added a clamp just forward of the fitting at the LU as a strain relief so the hose will stay as you originally intend it to be.
    You will probably want a sleeve over a portion of the braid so it will not scuff the transom. That hose will not take long to leave it's mark.
    Regards,
    Charlie North
    If it ain't broke, modify it.
    87 Glastron CVX20 with Yamaha ProV 150 power
    80 21' Superboat to be powered with a turbocharged 4 stroke OB
  3. #93
    Pickering and Lakefield, Ontario, Canada
    I like the idea of running this type of low water pickup, but without the nose cone on the LU, what about blow out? I'm running an OMC 200 on an 18' pad v style hull (Charger SK), with the propshaft about 1" below the pad, with a stock lower with the top 2 holes on each side filled in. I'm getting 82 mph when all the conditions are right. Trying to lift the engine higher drops my water pressure from about 20 psi to less than 10 psi. If I hook up a transom mount system, and get my motor higher, am I risking loosing steering control?
    Here's a shot of my rig.. don't mind the helmet, it was October and the helmet was keeping me warm
Name:	On the Otonabee in October 2014.jpg
  4. #94
    Aug 2004
    Venice, Florida
    I run a nosecone even with the pickup bu just because I almost run like a three point hydro. Back of the two sponsons and the botto of the bullet. The longer bullet gives me more tail lift. At top speed I have nothing but skeg in the water.
    I have no experience with these pickups on a V or pad bottom boat.
    21' Paramount
    Mercury 300 Promax
  5. #95
    Aug 2015
    NE Tennessee
    Quote Originally Posted by Mr. Demeanor View Post
    Now THAT just sounds like a totally, properly maxed out set up AND FUN !!!
    James
  6. #96
    Aug 2004
    Venice, Florida
    The concern I would have with a pickup ike this is disturbing the water right in front of the prop.
    21' Paramount
    Mercury 300 Promax
  7. #97
    Jul 2014
    Friday Harbor, wa
    I made a modification to my low water pickups. I added the "spray plate" to prevent water from shooting up the transom. It seems to work.
  8. #98
    May 2008
    Merritt Island, FL
    All good stuff. I am thinking about doing this on my current project boat w 300xs motors. I saw that someone hadnplumbed a LWPU to the hose flush port. I don’t completely understand the water path on these engines, but a little concerned if I did that, when the impeller is providing water at idle, that the water would flow backwards through the LWPU and not be cooling the power head. Am I concerned for no good reason?
Bob's Machine
