Results 166 to 180 of 445
Thread: Chrysler racing outboards
11-24-2015, 09:25 AM #166Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
THe first pic from the stern show carbs . Anyone have any numbers on how the two set up compared?
11-24-2015, 05:23 PM #167
Laker liked this post
11-24-2015, 06:01 PM #168
I scanned the original again and made it big, but there is no name on it. Could be Algon. Whoever made it, made it for that motor. The castings are pretty nice, no welding marks, no cobble up job there.
11-24-2015, 06:17 PM #169Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
Jack Oxley was the man behind making the drag stuff run, he was a long time friend of my father. They had Algon injection when they later went to the Jones hydro, Mark 75h is correct on the lowers.
11-24-2015, 06:25 PM #170Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
All the race stuff then just looked so good, pure purpose original ,mechanical from chemical potenial energy hot rod power. Just wild.
11-24-2015, 08:21 PM #171
After having mechanical fuel injection on our Gasser drag car(it was Endelie) I have a lot of respect for anyone using it on non intended applications!! Does anyone know when it was first used on outboards and and how much power increase it had on 2-strokes. I know that it had quite an increase on hp on our 402 ci AMC over the large (think they were called 4500 model) Holly carbs. That was back in the early 70s but I think I have it correct. There is nothin like the sound of a well tuned injected ,hi compression engine!!! Gary
11-25-2015, 08:45 PM #172Member
- Dec 2013
- southern md.
- 72
- 13
ADI ing, alt. driven ing./or all defective ing.!!!!
11-25-2015, 09:26 PM #173Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Pre CDI. 65 -66
11-26-2015, 10:44 AM #174Member
- Dec 2013
- southern md.
- 72
- 13
11-26-2015, 12:41 PM #175Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
1975-1976-1977 electronic on the 105 and others was a good system. In 76 the 105 bumped psi to 165 with the new ign , some had the new powerflow lower and leg. Probably the best of all the 105s until 78 when the new leg and one piece lu came in for all the triples and fours, except psi went down again to 145 and ign when back to breakerless distributor which wasn't as good as the points distributor for hours of use. The Prestolite electronic was next, your favorite I think.
11-26-2015, 02:24 PM #176I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
Checkmate 16' 140 Johnson
Laser 480 (?) 21' w/GT 200
24' Sonic w/twin 250 Johnsons
11-26-2015, 03:26 PM #177Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
At 140 she was in need of rings. 155-165 for that one . I run 140hp at 170 psi beautiful, factory was 165 , no prob on GOOD pump gas with good syn.oil and lots of ign 34* dwelled correct with a bit more jet and other things. Have a couple of 5s on the build one at 170 the other 195. Factory stacker 135HP is 175-185psi advertised to run on regular leaded back in the day . 150 HP stacker 195psi .
11-26-2015, 06:29 PM #178I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
11-26-2015, 08:55 PM #179Member
- Dec 2013
- southern md.
- 72
- 13
nothing like hi ring coated pist. and .070 cut on head,bigger carbs = 150,otherwise same as 135,head was same!!
11-26-2015, 09:08 PM #180Member
- Dec 2013
- southern md.
- 72
- 13
F5 150, back together last night, with belt drive dist. asmbl. using audi 5000 cap & trigger wheel,chry. orig. elect pickup, got rid of ADI,crossfiring broke crank,after 2 good runs,no tach. or speedo. good acel. will find out about spd. &rpm tomorow !! with 4 carb big bore with std plate instead of jet x mani. sngl. x pipe, dissapointing prefromance,6250 @ 85 mph,should be 95!!
