Results 16 to 30 of 34
    Sep 2006
    Key Largo, Fl
    Here's what is happening.The assembled height of the crank in the block is set by the lower main bearing and as the motor runs it slowly develops grooves in the block that are caused by the crank sealing rings wearing into the sealing surface on the block.When you change the crank there is a good likelihood the grooves won't line up perfectly,causing the bind,that's why the bind sometimes goes away with the lower cap loosened.It may wear itself in with no problem,I always remove the grooves from the block if I'm changing the crank,chris
  2. #17
    Big Rock, IL / Eagle River, WI
    well, now I don't know what to do.... The motor is completely assembled. When I torqued down the front half initially, the rotating assembly was smooth and quiet. It was not until I torqued the bottom cap to specs that the bind occurred. Some thoughts have been that the bottom cap is contacting the bearing and binding things up. The cure is to mill several thousandths off the inner face of the cap. I'm not sure I understand why the sealing ring surface would cause a bind "after" the bottom cap is torqued. It seems like it should have been tight without the cap installed.
    By the way, I am looking forward to getting your reeds. I ported the cages last night and going to lap them today.
  3. #18
    Sep 2006
    Key Largo, Fl
    When you installed the crank the seal rings dropped into the wear area grooves cut by seal ring wear in the block from the previous crank,all was well untill you lifted the crank up in the block by pushing up with the bottom main cap...now binding the seal rings vertically.If it still turns but is just a little tight i would run it a couple minutes and see if it loosens up,if not,take it apart,chris
  4. #19
    I don't mean to beat a dead horse.... but still trying to get a grasp on the problem. Your explanation was very good, the one thing I don't understand is how the bottom seal can actually lift the crank and cause binding. (unless I'm still not getting the picture). Since the seal is rubber, how can it put that much up force on the crank? oops, While I am typing this, I think I got it. Are you visualizing the crank in a vertical position? If so, why does the bottom cap put pressure on the bottom bearing? Shouldn't there be plenty of clearance between the inner face of the cap and bearing?
    sorry for just not getting it....
  5. #20
    Sep 2006
    Key Largo, Fl
    Here ya go....look at your empty block,you see a machined pocket on the bottom that receives the bottom main bearing.This pocket is open on the bottom,untill the botton main cap is in place,then the outer race of the bottom main is held captive by the outer diameter,the upper block flange,and now the bolted in place bottom cap,which serves to lock the outer race in place as well as hold the seals.The lower main bearing,a robust ball bearing,sets the assembled crank height,locked in its machined pocket,held up in place by the bottom cap.If the seal rings on the crank arent at the exact same position as the previous crank seal rings,they may bind in the wear shoulders on the block where the seal ring outer edges ride,chris
  6. #21
    WASHINGTON N.C.. I TOO HAVE A BOATING PROBLEM
    I had a small chunk come out of my crank, (where the sealing rings are held) because of that same reason.
    It was 1/2 the size of my pinky finger nail....but it caused BIG trouble.
    JOHN MASON
    '83/VECTOR/MERC 200-- SOLD
    '98 Quartershot T-3/ MERC 200
    "If your not living on the edge, your taking up to much space"
  7. #22
    Got It!!!!! I don't have the block in front of me so I was trying to picture in my mind (what's left of it!). What I didn't realize is that the bottom cap actually supports the outer race of the bottom main. Now it makes sense. Thanks for being patient and explaining the situation.
  8. #23
    Mar 2007
    My experience doing automotive line-bores causes me to cringe everytime someone mentions mis-matched assembly halves. The parts are originally bolted together and machined as an assembly. When mismatched, it is not likely that every surface will line up perfectly or that bore sizes will be correct. Misaligned surfaces and loose/tight bearing bores do not allow seals and bearings to function properly at high speeds/loads. That is where 'binding' comes from. My 2cents...
  9. #24
    Sep 2006
    Key Largo, Fl
    Boat2fast,in some cases your correct,but not this time,I believe.In the manufacturing process regarding outboard blocks there are different methods employed by different makers.Generaly speaking,there are two standards of block machining,the one you're familiar with -alighnboring,a system involving casting a block in one piece,drilling,tapping,dowelling,the mounting flange area,then cutting the front from the back of the block,through the flange,lapping the surfaces,and bolting them securely together.Only then is the final machining of the end caps and main ways done,achieving a perfect fit and resulting in a matched crankcase set,front and back,replacing one or the other is asking for trouble,or at least should not be attempted blindly.
    The other method( used in all v6 mercs I believe) is called "precision machined",a system where the front and back halves of the block are in fact machined to finished product separately,and become a matched set only after alignment dowelling pins are fitted by drilling the lined up( on a jig) front and back halves,resulting in a now matched set.This matching can be and often is disabled by the simple removal of the dowel pins.The halves are easy to line up at assymbly,the side to side takes care of itself,one has only to pay attention to the height of the front,make sure it's even with the back before tightening.I have removed dowel pins and mis-matched literally hundreds of blocks,I guess,over the years.Flatlanders binding is due to the seal rings,I'm confident,Chris
  10. #25
    just a follow up, I went ahead an pulled the front half and then reinstalled the end caps and torqued to specs.. The crank turns smooth and easy. The front half does have small grooves where the seal rings ride. I am going to clean those up and temporarily reinstall the front half and check for binding. Will update later...
  11. #26
    Mar 2007
    King Solomon wrote "By iron, iron itself is sharpened. So one man sharpens the face of another." Proverbs 27:17.
    I have learned something new; Thanks Chris.
  12. #27
    Sep 2006
    Key Largo, Fl
    Thanks,you're welcome,brother...
  13. #28
    real quick note, Thanks Chris and everyone else that helped me out with this problem. Sure enough, by removing the sealing ring grooves in the front half fixed the problem. Live and learn!
    Thanks!!!
  14. #29
    Did you bolt the two 1/2's together when you cleaned them up?
    Or did you do them seperatly?
    JOHN MASON
  15. #30
    I only did the front half. That eliminated the bind completely.
