Results 1 to 15 of 34
11-02-2010, 09:26 PM #15000 RPM
- Apr 2009
- Detroit
- 119
1980 Mercury 200 Front half change to an 86 front half 2.4 L
I have an 80 200 Mercury #5464805
I have an 200 Mercury 86 front half with carbs (complete)
Can I put the front half on this engine?
and will it work correctly with out problems?
I need to have the electric enrichiner on this engine instead of a choke set up for my application
11-03-2010, 06:39 AM #2Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,274
- 215
- 30
- 585
The front will bolt on I believe,I haven't done it,look at the crankcase mateing surfaces at the oil pump area to see if they will seal.The block from the 80 will have the inside bolt pattern on the heads,and no fingerports,The 81 225 was basically that block with a 7petal front,rated at the flywheel.The motor should run well,but won't make the power of a later finger ported motor,you'll need to work with the carb jets,Chris
11-03-2010, 07:00 AM #3Screaming And Flying!
- Springfield,La.
- 6,579
- 17
- 2 Thread(s)
I alwayz leeve out tha dowl pins on tha block halfs and let tha crank line tha front half...I have had a couple that didn't turn free, and don't recomeend use'in it if tha crank don't turn free after torque'in tha front half on......Also have run into the end seel cap(bottom) lock'in up tha crank after use'in mismatched fronts....
other than sum oddity type stuff, tha front should juss be a swap!!...Performance differnce won't be enuff to tell(if any at all)...JMO
11-03-2010, 07:16 AM #4
I just had that problem, where the the bottom cap was binding up the crank. If I loosened the bolts just a tad the crank would rotate ok. Is it ok run like that?
11-03-2010, 07:53 AM #55000 RPM
- Apr 2009
- Detroit
- 119
I am planning on using the carbs that came off of the 86 block (the 86 block has a hole in it from a piston) hence the swap questionwill I need to re jet seeing that I am using the 86 carbs?
11-03-2010, 09:16 AM #6
The block I sent you is the newer style with a good horizontal front half. Is there some reason you don't want to bolt your carbs on that one? What carbs do you have 86' intake?
11-03-2010, 10:02 AM #75000 RPM
- Apr 2009
- Detroit
- 119
the one you sent me is already assembled....finished it saturday afternoon with new rings ect
11-03-2010, 10:22 AM #8
Great, I didn't realize you were building two motors.
11-03-2010, 11:55 AM #95000 RPM
- Apr 2009
- Detroit
- 119
building 4
11-03-2010, 01:01 PM #10
I've run inta that a couple times. I removed tha snap ring at tha big bottom bearing and gave it a light smack (bearing) with a tool used to install a new bearing, used a NEW snap ring and tha bind went away (and stayed away after runnin' a while). Sometimes it only takes splittin' a fine red 'unt hair ta bring things back ta where its supposed ta be..............Maybe I've just been lucky, donno....
And NO, don't run it that way...............
11-03-2010, 01:17 PM #11
Thanks, I'll give it a shot.
11-03-2010, 07:58 PM #12Junior Member
- Aug 2010
- texas
- 13
if you dont use that front half, would you be willing to sell it? I have a 175 merc i'm looking to upgrade.
11-03-2010, 08:27 PM #135000 RPM
- Apr 2009
- Detroit
- 119
which front half? the 1980?
11-04-2010, 07:54 AM #14Screaming And Flying!
- Springfield,La.
- 6,579
- 17
- 2 Thread(s)
Use tha jets on tha carbs U gunna use!!!....Even tho both motaz are 200 hp, each carbs have diffrent jet sizes for thier respective numbers....Mercury's better ideer!!!.....Exzample, My WH-31's(88' 200 2.4) haz .080/.082's....My wh-22's(225 2.4) haz .072/.074's......U put .072's in them wh-31s, and U have juss fried a 200 mota!!!!....IF, one ov thoze manifolds are X-drill'd, U have open'd a complete new can ov wormz...X-drilld manifold, step up 4 jet sizes(.008").....JMO
11-04-2010, 08:46 AM #155000 RPM
- Apr 2009
- Detroit
- 119
no cross drilling here all stock parts
