Results 1 to 6 of 6
10-14-2010, 04:15 PM #15000 RPM
- Dec 2006
- Ponchatoula, La.
- 186
- 7
prop change ? or gearcase change.
My 22' apache scout w/300x is only pulling to about 5200 rpm's since i bought it. It was fine at first because i wanted to get a bunch of seat time before i really opened it up. I am running a 1.62 sportmaster and a 24p trophy plus 4 blade. I know the motor is rated up to 6700. I have checked the linkage and it is opening fully. Should i go down in prop pitch or change gear ratio. I know the sporty is not the right lower but i should still be able to get the rpm's up. Any thoughts?
86 Apache Scout 300X
INDIAN OUTLAW
10-14-2010, 07:44 PM #2
I ran into the same problem with a 25 trophy would hit my rev limiter at 6300 rpms with a 1.75. When I went to a 1.62 it would only turn 5200 also but the 1.62 wouldnt even get out of the hole with my 28 trophy. THe 1.75 turns the 28 5800 rpms. I would get the gears changed. JMO
10-14-2010, 08:01 PM #3
I have a friend that has 1.75 gears and is looking for 1.62s if you are interested in doing a switch PM me.
10-19-2010, 11:58 AM #45000 RPM
- Dec 2006
- Ponchatoula, La.
- 186
- 7
10-19-2010, 11:59 AM #55000 RPM
- Dec 2006
- Ponchatoula, La.
- 186
- 7
11-13-2010, 09:36 PM #65000 RPM
- Dec 2006
- Ponchatoula, La.
- 186
- 7
What difference will the 1.75 make comparing it to a 1.62? Thanks in advance!
INDIAN OUTLAW
