Results 1 to 11 of 11
Thread: clear coat
09-21-2010, 11:06 AM #1Member
- Jun 2010
- cleveland tn
- 68
clear coat
what kind of clear coat do i need to do my boat i cleared it with omni i got from a body shop they said it would work stayed on about a month or so now starting to bubble up
09-21-2010, 11:46 AM #2
09-21-2010, 12:11 PM #3
Omni is an economy line of PPG acrylic urethanes and it is extremely durable. Concept is at the premium end of the PPG paint line, and it too is extremely durable. Both are great paints when used according to instructions. Concept is probably a little more forgiving, but that comes at a price.
Bruster's Mercury solid motor mounts, details here:
http://www.powercatboat.com/Bruster/Bruster.htmlI'm been living in fast forward, now I need to rewind real slow....
09-21-2010, 12:16 PM #4
09-21-2010, 01:46 PM #5
I used Napa brand clear coat on my boat four years ago and it still looks great. I did do a lot of sanding and prep work and more and more sanding.
83 Checkmate Predictor/Xr2
09-22-2010, 12:55 AM #65000 RPM
- Nov 2006
- 173
I clear coated my 1970 Tahiti with Dupont 780S Centari, with 793S hardener/activator. If you use this stuff, you must wear a respirator.
09-23-2010, 08:54 PM #7
How does Matrix work for you. At 1/4 th the price seems like something has to give. I like how the Concept goes on and how it will buff. The Omni goes on OK but cures glass hard and is more difficult to work on after it is down. I like the price of the Matrix and there is a local dealer but??
09-23-2010, 08:58 PM #8
09-23-2010, 09:05 PM #9Bruster's Mercury solid motor mounts, details here:
09-23-2010, 09:29 PM #10
PPG Omni has an epoxy primer similar to DP.....It is MP170 with the MP175 catalyst. Same mix ratio and even smells similar..... may just be DP repackaged and sold cheaper.....
Quartermaster
XB2002 W/S3000
09-24-2010, 07:40 AM #11
