Results 1 to 3 of 3
    new york babylon
    3.0 crank assembly question
    how do you align the bearing dowel pins to set the crank in ,ive tried but no success yet,any tricks??? its not like a 2.4 crank thanks tripps
    Jun 2004
    port st. lucie, fl
    you just have to have patience, i usually mark the bearing 180 degrees from the pin hole w/ a marker, that way when i'm putting it together i know where the dowel pin holes are in the bearing
    new york babylon
    Thats what i did thanks tripps
