Results 1 to 3 of 3
    Bensalem, PA
    jetting with wh22 carbs
    i just went to wh22 carbs on my 2.4 200s. i didn't get jets with the carbs so i used the ones from my old carbs. i have a set of velocity stacks and and boysen reeds. i went from 80 82s to 82 84s with the old carbs when i put the reeds and velocity stacks on. i ran the wh22s and now my plugs are pretty black. the book says stock would be 74 & 76s. should i go with 76 and 78s or stay with my 82 & 84s. thanks
    Dec 2001
    For some odd reason the 22s use smaller jets?????? A bigger bore carb should use bigger jets. I don't know why but Merc did something in the carbs not seen by most. Lean it till it's happy.
    TX......somewhere?
    Quote Originally Posted by demag67 View Post
    Yes, then read 'em and go from there...........
