Results 1 to 6 of 6
Thread: Evinrude V4 140hp fuelpressure ?
09-08-2010, 06:12 AM #15000 RPM
- Apr 2006
- Belgium - near city of Ghent
- 161
Hi,<O</O
What is the required fuelpressure on a stock early 90’s Evinrude V4 looper 140hp ?
What happens if fuelpressure is too low ?<O</O
What happens if fuelpressure is too high ?
<O</O
<O</O
Thanks,<O</O
T.
09-10-2010, 11:11 AM #25000 RPM
- Apr 2006
- 161
anyone ?
This should be easy questions but my service manual doesn't mention a exact value for pressure nor flow.
Basic element in my fuelsupply setup is the external Holley fuelpump. I see this is a rotative volumetric vane pump. As these Marine Holley's come in a few varyties I'd like to check if the previous owner did a good job selecting the correct one.
Therefore my questions, what happens if fuelpressure is too low/too high ? And what is the safe way to go ?
My guess is that low fuelpressure could cause powerhead damage as there is not enough lubrification ??
Any reply is welcome. Thx, T.
09-10-2010, 11:18 AM #3
from what I remember, 6 - 7 psi, low pressure will starve the motor/ lean it out. too much pressure will not let the needles seat and flood the motor.
09-10-2010, 02:14 PM #45000 RPM
- Apr 2006
- 161
thanks ! What does "lean it out" mean exactly ? English is not my native language...
09-10-2010, 04:08 PM #5
lean out = not enough fuel resulting in a melted piston
09-11-2010, 09:19 AM #65000 RPM
- Apr 2006
- 161
Auwch !
So I can settle for a Holley red fuelpump 67gph @ 5psi without regulator ?
http://www.holley.com/HolleyCatalog/...pageNumber=135
