Results 61 to 75 of 154
Thread: The OMC Cross Flow Thread
11-22-2022, 06:56 AM #61Member
- May 2013
- Michigan
- 45
How do you get past the 6200 rpm limiting power packs?
11-22-2022, 07:29 AM #62
Xp has stiffer motor mounts. Considering the age you probably want to pin them. Didnt the xp come with higher rpm limit power packs too?
11-22-2022, 07:39 AM #63Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
The bad rpm range is 64 to 6600 as for the rpm limiter try to find an original set of 79 to 82 power packs as they did not have limiters in them. The older packs will need wire end changes at the coil.
Forkin' Crazy liked this post
11-22-2022, 11:24 AM #64
I've seen 62's and 63's in the later fishing motors with bathtub heads. My 1981 that came with the tight heads and a factory recommend 30* of overall timing came with 64's. Factory jets I'm told we're drilled undersized then reamed to the finished size. I do know that APBA hydroplane racers think nothing of soldering closed the orifice and drilling to the desired size. Keep in mind that even the best drill bits will always make a hole that is slightly oversized, which is not a bad thing.
NRA Life Member
58' Farmall Cub
Is that your mama's boat?
"I said I didn't have much use for one. Didn't say I didn't know how to use it."- Mathew Quigley
11-22-2022, 03:27 PM #65
Depends on what carbs and the year on what jets. The last two year XP GT had the best carbs. I've used several different years, and racer told me the last two years were the best. Of course he was right!
I don't like drilling jets, but that is just me. You really need reamers to get a smooth cut and then there is the chamfer that needs to be in place.
11-23-2022, 03:21 PM #66Member
- May 2013
- Michigan
- 45
11-23-2022, 03:30 PM #67Member
- May 2013
- Michigan
- 45
Hearing that, I probably don’t want to drill out my own jets. I like a nice starting and idling engine. Racers care only about WOT so I can see them not minding driller jets and not messing with perfection. I assume the jets are a standard type of jet you can buy many places?
11-23-2022, 03:34 PM #68Member
- May 2013
- Michigan
- 45
11-23-2022, 04:23 PM #69
I have both year carbs of the XP/GT 2.6L. And they were jetted differently if I remember right. I was running both, but used the last year 2.6 carbs on my 235 and my 2.6 XP/GT and they worked the best. My last was just a new replacement XP/GTblock when I bought it. But had the CNC cut ports. The old 1980 carbs had 4 circuits instead of 3 like the newer XP/GT 2.6L carbs. Newer XP/GT 2.6 carbs brought that old 235 alive.
11-23-2022, 04:36 PM #70Member
- May 2013
- Michigan
- 45
11-23-2022, 06:15 PM #71
theres a few good threads on this process. This one has pics its pretty easy
https://www.screamandfly.com/showthr...wer-mtr-mountsHydrostream dreamin
11-23-2022, 06:15 PM #727000 RPM
- Central Florida
- 2,643
- 37
- 32
- 219
Two different sets of carbs in 1984 and another in 1985. So three variations and all jetted differently. If I remember correctly.
I suggest checking the part numbers on the power packs to see what you have. May have been changed back in the day to older unlimited rpm or to who knows what over the years to keep it running.
And go through the carbs to see what jets it has and which carb version. They should have tags. And new jets are not available but can be found.
11-23-2022, 10:22 PM #73Member
- May 2013
- Michigan
- 45
I’ll see what carbs and jets and power packs I have. I may need power packs or at least one and maybe some coils. I tried the boat once at it would hardly accelerate, topped out at 40 once it finally planed. May have some dead cylinders.
For jetting, does anyone have a list of carb part numbers and jet sizes? Maybe helps when buying used parts and engines.
As for setting timing to 26 deg, I think the original spec is 30, so that means you guys are recommending 26 deg before TDC, more RETARDED than the factory?? OMC had it too advanced? 30 deg would do some damage? It seems anyone that mods engine says to advance timing for better performance and lower fuel consumption.
11-24-2022, 07:21 AM #74I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
Checkmate 16' 140 Johnson
Laser 480 (?) 21' w/GT 200
24' Sonic w/twin 250 Johnsons
racer liked this post
11-24-2022, 07:48 AM #75Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
I think my 2.6 XP was an ‘83.
Gary is correct the 2.6 XP built 83 to 85 and yes they had different carbs that require different jet so you need to be careful. Jets are specific to E/J and need to be a C series for those carbs as flow direction is different than the D series jets for the later engines.
