Results 16 to 30 of 154
Thread: The OMC Cross Flow Thread
08-28-2010, 08:52 AM #16
Your right, I'm wrong. Happy now? Oh and I never said that you said anything about a lost locater pin, but that is the only way I can see to hang a ring in a stock port. Or if your rings got caught in the port (could happen on any motor but not as likely on a crossflow), sounds like the machinist didn't champher the port when he bored it. I use to work at an OMC dealership in the early 80's for what that is worth. Well good for your dad working for OMC. How that proves your case is beyond me. I have literally hundreds of hours on OMC Xflows, but that realy doesn't mean **** either I guess. Have a nice day.
08-28-2010, 07:22 PM #17I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
Checkmate 16' 140 Johnson
Laser 480 (?) 21' w/GT 200
24' Sonic w/twin 250 Johnsons
08-28-2010, 09:49 PM #18NRA Life Member
58' Farmall Cub
Is that your mama's boat?
"I said I didn't have much use for one. Didn't say I didn't know how to use it."- Mathew Quigley
08-28-2010, 10:28 PM #19
08-28-2010, 10:53 PM #20Junior Member
- May 2008
- atlanta
- 29
Man, I've been waiting on this thread to come around. I got a 79 Viking with a '83 2.6L XP......been GPS 79 MPH with a 26" through hub turbo out of the box. Want to find a suitable SRX to get it well into the 80's. Was told when I bought the boat it had been 90+ with a 30" cleaver, but most dont run a cleaver on a V-pad 'stream.
Anyone got any good info on the 2.6L XP's?
08-29-2010, 09:49 AM #21Screaming And Flying!
- Oct 2003
- Cobourg, ON
- 7,194
08-29-2010, 09:59 AM #22
I know a bunch of us could ramble on for a while about your motor, but the most important things for keeping it from blowing up are always use fresh high octain fuel, correct timing, and never over prop your motor. Do a cross flow search in the tech forum and feel free to ask if you can't find what you need.
You can do way better than that turbo prop. An SRX, chopper, Mazco, or any other over hub high perf prop in the 27-30" range should easily get you into the 80mph range.
That 2.6 xp will eat up Merc 2.4's all day long.NRA Life Member
58' Farmall Cub
08-29-2010, 10:27 AM #235000 RPM
- May 2004
- Eastern PA
- 594
- 29
- 54
Forkin...Check PMs. Thanks.
08-29-2010, 10:57 AM #24
08-29-2010, 03:24 PM #25
A 1983 XP 2.6 in 1986 w/a 26" Raker @ 6300 (8% slip) and 77 MPH's (indicated)
<a href="http://s290.photobucket.com/albums/ll255/Instigatorspixs/?action=view¤t=conquestatspeed.jpg" target="_blank"><img src="http://i290.photobucket.com/albums/ll255/Instigatorspixs/conquestatspeed.jpg" border="0" alt="Photobucket"></a>
Same boat w/a looper.
<a href="http://s290.photobucket.com/albums/ll255/Instigatorspixs/?action=view¤t=conquest.jpg" target="_blank"><img src="http://i290.photobucket.com/albums/ll255/Instigatorspixs/conquest.jpg" border="0" alt="Photobucket"></a>
Not a flow but a cleaver on a Stream.
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf" flashvars="file=http%3A%2F%2Fvid290.photobucket.com%2Falbums%2Fll255%2FInstigatorspixs%2Fstreamat101 .flv">Last edited by Instigator; 08-29-2010 at 04:26 PM.
08-29-2010, 09:39 PM #26
The Cross Flow Bible
Here are the 9 pages (thanks Forkin). This isn't the first time this has been on S&F. I couldn't find it, probably because of the new format. Some great info!
Credit for this work goes to Alan Stoker.
Last edited by john j 80 viking; 08-30-2010 at 09:16 AM. Reason: correcting a mistake
NRA Life Member
58' Farmall Cub
09-09-2010, 08:17 PM #27Member
- Nov 2008
- bayou state
- 82
Correct me if I'm wrong (and I probably am), but I was under the impression that when you modify the 235 according to the 9 pages above it basically tuns it into a race only type of engine. Is this correct or if one is built like this it can have good longevity aswell?
09-09-2010, 10:02 PM #28
I am no Guru, but IMO other than the added stress from the tighter heads and the actual power increase I don't see anything in the 9 pages that would turn a 235 into a time bomb.
The biggest thing I think you could do for reliability is to use low ring pistons.
They recomend retarding the timing back to 26 or 28*, and recomend 62-6800 rpms which is conservative for a race motor.NRA Life Member
58' Farmall Cub
09-10-2010, 07:33 AM #295000 RPM
- Jul 2008
- Key Largo, FL
- 352
Does cutting the piston skirt cause more piston slap or any longevity problems? I asked one outboard guru about this and he said it causes no problems and offered a pretty good explanation but I still wonder.
86 18ft Motion (Action copy)
98 Quartershot T-3
09-10-2010, 09:04 AM #30
Never had any problems. The XP/GT motors came with the piston skirts cut from the factory.
