Results 1 to 15 of 243
08-24-2010, 04:34 PM #15000 RPM
- Aug 2009
- Azle Tx
- 594
Need Some Help And Advice......on refit/rebuild...Sleek Rebel
I am cleaning up and old hull for my dad so he will have a boat.
I need to clean out all the paint and carpet glue from the inside of the boat and glass in the old jet pump holes. After that I need to put new stringers a floor and a transom back in the boat before fix the top deck.
I haven't bought any supplies yet, I have just started cleaning the inside of the hull out. Any guidance and advice would be appreciated deeply.
Thanks
John VaughtLast edited by John.Vaught; 09-08-2010 at 12:26 PM. Reason: found out what the boat was
08-24-2010, 04:38 PM #2
post up some pictures and we all can help you from there
7 to 3pm 5 days a week
Custom Fiberglass and Paint
In Business since 1984
for sale
08-24-2010, 04:40 PM #35000 RPM
- Aug 2009
- Azle Tx
- 594
08-24-2010, 05:01 PM #4
lol thats funny i got the same boat gutted out at the shop now
sometimes easy off works most of the time you either sand blast or sand it off
did you save a pattern for the stringers that helps
for sale
08-24-2010, 05:22 PM #55000 RPM
- Aug 2009
- Azle Tx
- 594
Yeah I have one stringer and the keel beam left over, I'm trying to convert the boat to an outboard.
08-24-2010, 05:27 PM #6
ill take a look at mine i cant remember right now why we scraped that idea on this hull
for sale
08-24-2010, 06:11 PM #75000 RPM
- Aug 2009
- Azle Tx
- 594
Well let me know if there is a problem. I am going to redo the deck and make it a flat deck flats style boat . I hope to get it to run about 70mph with a 200. He likes to go fairly fast and fish.
His last boat was a bullet but with things being the way they are a new bullet isn't in the cards.
Thanks
08-24-2010, 06:19 PM #8
john i think it was cause we would have to taottaly change the transom theres a small pocket for the jet pump on this one and not enoph room to mount up a 20 inch motor and get it at the right hieght
but you might be able to do a 15
let me see another pic of the bottom transom straight on
for sale
08-24-2010, 08:27 PM #95000 RPM
- Aug 2009
- Azle Tx
- 594
This boat is a v all the way back minus the cut out for the intake and the transom is flat from hull side to hull side. It reminds me of a donzi classic, it was a sleekcraft rebel.
The transom is about 22 inches tall.Last edited by John.Vaught; 08-24-2010 at 08:31 PM.
08-24-2010, 08:36 PM #10
ooh ok it just looked like mine from the pics
you should be good to go then for a fishing boat conversion
i would still like to see the transom straight on
chine location etc
for sale
08-24-2010, 08:44 PM #115000 RPM
- Aug 2009
- Azle Tx
- 594
No problem I will get some pictures tomorrow after I drag a big tree limb that fell out of the way its to dark right now anyway.
Hey whats the best way to clean the inside of the boat with out grinding the roving down? I used oven cleaner to get some of it off, I sprayed it off after about 30 minutes should i have left it on there longer? Should i hit it again with oven cleaner? Can I just use a grinder with a wire wheel on it?Last edited by John.Vaught; 08-25-2010 at 01:27 AM.
08-25-2010, 01:51 AM #125000 RPM
- Aug 2009
- Azle Tx
- 594
08-25-2010, 12:06 PM #135000 RPM
- Aug 2009
- Azle Tx
- 594
08-25-2010, 12:24 PM #14
yea that's different from mine the tops are just about the same
i would say go for it look like it should work good as a outboard
for sale
08-25-2010, 01:24 PM #155000 RPM
- Aug 2009
- Azle Tx
- 594
AFR,
I have never filled a hole in fiberglass bigger than my fist what do you suggest I do with these big cut outs? How should I go about glassing them back in?
Also what kind of paint stripper should I use?Last edited by John.Vaught; 08-25-2010 at 01:26 PM.
