Results 1 to 11 of 11
08-19-2010, 06:27 PM #15000 RPM
- Feb 2008
- Hudson, WI
- 380
- 29
Livorsi GPS Speedo Hookup Question
Hooked up all my Livorsi gauges last summer except for my GPS speedo. Working on that today. Plugging the Antenna Receiver wires seems to be straight forward as well as the Tattle Tale GPS Recall wires. Then there are three wires left over. A White, Red, & Black. The Black & Red are easy enough but I'm assuming that the White is for a 12 Volt Key On Power???? I have an ETEC 200 on this boat and the wires going into the other gauges are Black, Green, Purple, & Blue. Where should I tap into with this White wire?? Or any other tips would be appreciated.
Thanks in advance.....Robb
08-19-2010, 06:40 PM #2
Do you have the installation instructions? If not they are probably on Livorsi's web site.
08-19-2010, 07:49 PM #3
08-19-2010, 08:46 PM #45000 RPM
- Feb 2008
- Hudson, WI
- 380
- 29
Thanks guys for the information. I still am in need of some info however. I wired the antenna as described. I then wired the red direct to a power source. I then grounded the system and the gauge works. However, I would like figure out where to tap into the system so that when I hit the key, the GPS speedo system powers up. One of the Green, Purple, or Blue wires must be a 12 Volt Powered by the ignition switch. Any idea which one it is?
The white wire is for the gauge lighting.
Thanks in advance again........Robb
08-20-2010, 04:44 PM #55000 RPM
- Feb 2008
- Hudson, WI
- 380
- 29
Got it up and working. Blue wire is for the gauge lights. Purple wire is 12 Volt key-on power. Speedo works like a champ!
08-22-2010, 08:25 AM #6
great!Back to school for me,too!after lov2gofast got me back in the waterrunning I was screwing with the recall switch and didn't know about the avg.speed feature,was getting pissed cuz I knew I was going faster than posted speed!after reading americanram's post now understand!stupid old people need lots of help!!gotta love S&F!!
why ask me ?
08-25-2010, 03:14 PM #7Junior Member
- May 2004
- S. Fl
- 7
Hope it lasts longer than mine.
1st one lasted about 3 months & 2nd one lasted about 6 months.When the Juice kicks in...the talking Stops..
08-25-2010, 03:50 PM #8Member
- Oct 2009
- GLADWIN,MI
- 74
What went wrong with it? Mine sometimes resets itself on highspeed passes. I figured it was just nature of the beast.
08-25-2010, 03:58 PM #9Junior Member
- May 2004
- S. Fl
- 7
One day it turned on and read between 11 & 14 mph ( even when I wasn't moving ).
The next one reads ( broken numbers, you can't tell what is says ). Have not changed it ( just happened).When the Juice kicks in...the talking Stops..
08-25-2010, 04:03 PM #10Member
- Oct 2009
- GLADWIN,MI
- 74
Got it. I have the one with dial. Works good 99% of time.
08-25-2010, 04:21 PM #11Junior Member
- May 2004
- S. Fl
- 7
