Results 1 to 12 of 12
Thread: Omc crossflow
08-19-2010, 01:47 PM #1New Member
- Aug 2010
- muscle shoals
Omc crossflow
I have a 1997 omc 90 hp crossflow , is there any bolt on parts that will help performance , carbs , reed blocks , etc
08-19-2010, 01:55 PM #2Member
- May 2006
- Houston, Tx
- 90
Hate to say it but the best bolt on is a 135.
Oh and if its really a 1997 its a looper.
08-19-2010, 02:09 PM #3
Not much in bolt on parts, you could have the ports modified to a 115 and change the heads...
08-19-2010, 02:16 PM #4New Member
- Aug 2010
- muscle shoals
its a 90 degree motor with removeable exhaust cover , you sure its a looper! build date 12/97
08-19-2010, 04:58 PM #5Screaming And Flying!
- Oct 2003
- Cobourg, ON
- 7,194
It's a crossflow, I have a 95. Best just to find an earlier 140 drop-on.
08-19-2010, 10:07 PM #6Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,272
- 215
- 30
- 585
Our reeds will idle/accelerate better,early 80's heads will improve compression,crankcase stuffers help,remove airbox cover and jet up 1or2 thousandths on the mains,not too much more to be done without going into the motor and spending a lot more $.
08-19-2010, 10:33 PM #7Screaming And Flying!
- Oct 2003
- Cobourg, ON
- 7,194
08-21-2010, 04:58 AM #86000 RPM
- Oct 2003
- LAGRANGE, IL
- 1,277
- 11
- 14
Bolt-on parts: Get a set of larger 110/115 carbs-with the 1 5/16" throats. Ditch the bathtub heads and find a set of very early 140 crossflow heads from the 77-78 timeframe. Install a set of 4 NLA rubber intake stuffers 322684. Composite reeds are a great addition. If you want to get into machining (teardown,) you can port it and add the exhaust bubble on the back of the engine. Your factory power pack will limit revs to 5800 rpm.
08-21-2010, 08:43 PM #95000 RPM
- Alabama
- 897
- 28
- 29
- 58
- 81
Chris Carson has a special reed to fit a special cage and with stuffers they work real well. Isn't that right Chris?
08-21-2010, 10:43 PM #10Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,272
- 215
- 30
- 585
Freddy,your correct.I have the cut cages and reeds available,but I don't know that the motor in question could benefit from them,maybe a little overkill,what do you think,chris
08-22-2010, 09:11 AM #11Screaming And Flying!
- Oct 2003
- Cobourg, ON
- 7,194
Chris could you please PM me details of this special cage?
08-22-2010, 01:55 PM #125000 RPM
- Alabama
- 897
- 28
- 29
- 58
- 81
Jeff I sent Chris one of them. I think I have four of them left.
