Results 16 to 19 of 19
08-04-2019, 03:36 AM #16
This actually works It was used on some of the rally cars in Europe the main one i remember was the ople manta
Water has a very high heat of vaporization. As the ambient temperature water is injected into the engine, heat transfers from the hot cylinder head and intake air into the water. This makes it evaporate, cooling the intake charge. A cooler intake charge means it is more dense (higher volumetric efficiency) and also has a lower tendency to knock. However, the water vapour displaces some air, negating some of the denser intake charge benefit. Knocking is generally more of a problem in forced induction engines rather than naturally aspirated, so this can help prevent it. On electronic ignition systems the ignition timing is generally retarded to prevent knock from occurring but with water injection it can be advanced closer to maximum brake torque (MBT) timing for additional power.
It was phased out in the mid 80s not sure if that was because of the fuel injection systems becoming more of the norm or for some other reason.
08-04-2019, 01:50 PM #17
If you want water injection, just get ya one of them stock 300xs cowls ...
Say Cleetus, how bout them Chinese turbolator's ...
That "progressed" 75 HP shot at the end ... is a little much for a 2-stroke ...
Those little "whippit" canisters can get expensive ... LMAO Maybe an "electric supercharger" will make some real power ...
Cleetus says, "Instant-boost with nitrous and turbo is the way to go ...
08-04-2019, 05:34 PM #186000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
08-04-2019, 10:53 PM #196000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Water progress to methanol injectors works better for cooling the intake and adds o2
