Results 1 to 3 of 3
08-09-2010, 09:59 PM #15000 RPM
- Jul 2005
- Crystal River, Fl
- 491
- 10
where do i get started diagnosing trailer brakes?
i have surge/drum brakes on my formula trailer. im pretty sure they arent working. I have no clue where to start. I think the cylinder (or whatever its called) is bad. Seems that the tongue goes in way more easy than it should when stopping....
1986 Laser 380 comp- being re-done... slowly...
http://www.screamandfly.com/showthre...23#post2859423
1997 Hewes Bayfisher 16- 90 yammie
1982 Laser 380- 200 merc- SOLD
08-09-2010, 10:40 PM #26000 RPM
- Sep 2002
- Solvang, Calif
- 1,459
- 78
- 29
- 160
- 155
First check the brake fluid level, should be full, if not your leaking somewhere. Attatch the stinger and ball to the trailer to use it to bleed the brakes. If it's full check the (drum) adjustment. Other wise the Master cylinder is bad(Bypassing)
Gary
02-11-2011, 06:02 AM #35000 RPM
- May 2008
- Glen Spey, NY
- 402
TAKE THE TRAILER OUT AND HIT THE BRAKES THEN PULL THE WHEELS ON THE BRAKE AXLE AND SEE IF THE SHOES OR PADS ARE TOUCHING IF SHINY AND SMOOTH THEY ARE PROBABLY WORKING AND MAY JUST NEED TO BE ADJUSTED. IF RUSTY DEFINATELY NOT WORKING. OTHER WISE AS SAID BY gfinch HOPE THAT HELPS.
