Results 1 to 3 of 3
08-06-2010, 11:20 PM #1Junior Member
- Jul 2010
- crystal river, Florida
- 13
engine height question. how much will too deep effect holeshot?
I've been fighting this setup for 2 months now. Long story short, I bought a 16' 7" Javelin Venom with no motor, and I put a 140 Johnnyrude looper with a 20" shaft V6 gearcase on it. It has been a bear to get the motor running right, but I'm on the right track. The boat is still tough to get on plane with a 22p Raker. I literally have to take a few steps toward the bow to get the process started. Yes, I know it probably isn't safe, LOL
Once the bow starts down its a rocket up to 55mph at about 5300 rpm. Motor is mounted as low as possible on the transom.
I used the motor height measurment method here( http://www.bbcboards.net/zerothread?id=65514 ) . 16 3/8" to the pad, and 7 3/4" to the propshaft. looks like im 5 1/8" too high. I have a manual jackplate that I hope to install tomorrow or Sunday.
My question is, how much effect is the motor being so low having on my planing?
08-18-2010, 12:02 AM #25000 RPM
- Aug 2009
- Azle Tx
- 594
Well it should plane well with the motor mounted deep, it definatly shouldn't blow out. I think you need to try some different props.
08-18-2010, 08:29 AM #3
Hi. you say to get the engine running right . If that,s the case maybe it,s still the engine and not so much the prop. A healthy 140 looper should accellerate a 22 raker well thanks.
free spirit / ONTARIO, CANADA.
