Results 1 to 3 of 3
    Aug 2009
    fort lauderdale fla
    allison river racer looking for set up
ID:	213493who knows ? best............your boat knows how it wants to run THE BEST..
    just gotta' find it again after 15-20 years
    so I still have my old 1991 allison rr
    picked it up at the factory one day loong ago..
    . musta had 10 engines on this boat..
    back new I ran the drags with a 1992 150 fastrike evinrude.we had it dialed in BACK THEN
    remember your grandpa' telling you he forgot more than you know..?
    right now the prop shaft is 1 inch below the pad, with the bobs manual turned in for minimum setback..I pulled the 29 sst rx 5900 on the caribbean club to tiki bar run about 6 weeks ago
    ran good going down...coming back it seemed stuck to the water not getting loose...and when I trailered up i noticed the bobs cone had shed most of the epoxy and there was a big patch missing.........
    maybe it was the flats i burned across but since BOBS put the cone on in 1993 after almost 20 years all i could do was send it back to bobs for a redo
    DAMN it came back today.
    I told robert over there about this gearcase, he remembered the drags from 1994 and said he would look out for the Allison nosecone setup..
    IT looks sooooo good... soo good.......DAMN i'm gettin ready !! TO RIDE!
    but now..I have to find it ALL AGAIN with this 1991 faststrike 175 on my rr
    I THINK I REMEMBER the 1993 set up with basically the same motor was ;
    bobs jack turned out for 5 inch set back
    prop shaft straightedge level with pad
    allison custom prop washer that moved prop back about 1 inch
    back then it was the drags in b stock pullin a 26 allison drag chopper 6500
    just cut the 2 orange wires to the pack to defeat the rev limiter and add .002 to the high speed jets
    now this next week
    I'm gonna' try
    1st run with jack still turned in and raising the jack to prop shaft level with the pad no rev limiter 29 rx nice new fresh bobs allison cone
    I got 83 on gps in the keys...an inch lower and at 6000 feeling the rev limiter
    this time no rev limiter prop setback spacer and fresh nosecone and up an inch
    Back to the first sentence
    I want to get the BEST TOP END SPEED
    and ok you guys please dont say put a merc on it
    just give me a GPS 90 and I think thats enough....91..92
    I'm going for a
    GOODRIDE...............and turning that dial..looking for the BEST
    LET's RIDE !
    Aug 2009
    fort lauderdale fla
    looking for more.....TOP END with 1991 allison river racer
    not much ----set up input....SO;
    -maybe its..- better talking to my self and answering my own questions...
    ....because..
    nobody else needs to care
    I need to and care for----- at least 90 mph with my 175 fastrike on the allison r/r
    is this b.s? only when i'm done I think 90's EZ
    the 29 rx at 6080 with the e-tec 200 gave 83 uhhh i got the video at joels outboard--you tube
    so can a old school carb...60 degree rude catch the big--- nine ohhhhh---- 90mph
    ..I think I can,
    I think I can
    and I know I have to dial the setup in better than the you tube video of carribean club to tiki sandbar run from about 2 months ago..
    THAT was my last run
    so whats NEW and attempting a faster setup?? gotta' FIND 8 MPH NOW!
    Changes made for next run........
    ..fresh bob's cone for alli
    rev limiter bypassed
    same ...29 rx but now with with prop setback spacer
    added 1 inch up on bob's jack
    this was ... from 83 mph set up with no nose cone with e-tec 200
    this week is about gone but trying for monday august 16 th at markham....we will be the only ones there
    () ..90//90...---90....90 gps ...90... ..small block rude..90....... I'll write myself back and add video/pix
    cause next week is''''''GOODRIDE
    LET's RIDE !
    Windsor, Ontario
    I would expect 90 with 175 to be possible. My SS2000 with an old XR4 runs 89+. Of course I have a G force tuner which must be worth a bucket of HP
Bob's Machine
