Results 1 to 15 of 29
    Jul 2010
    miami fl 305
    action marine prop help
    i have a 1985 19 action marine with manual jack plate and 89 225 jhonson looper wat prop can i use with 4 ppl it wont go no wher it will just slip with 1 or 2 ppl start triming it will go but takes long time.. wat prop can i put wat setup can i use ? i have a raker 26p
    Jul 2008
    Key Largo, FL
    26 or 28 SRX or Hoss.... I am running a 28 Cleaver but it takes allot to fly the bow.
    16.9 Action W/ 135
    * Sweet tooth suicide*
    17 Motion W/250 XS
    *Madness*
    Quote Originally Posted by GDM View Post
    in nasty bay chop the ride on a small v bottom sucks , in sloppy conditions a cat goes right over it like a perfectly aligned rolls royce and the v is like a daewoo with 4 diffrent height tires and bent control arms
    May 2009
    catskill ny
    contact beefy on the boards. he had an omc action that flew and from time to time had it loaded to the hill with people and coolers
    1990 hydrostream virage diamondpower280
    Nov 2007
    Tarpon Springs FL/ Queens. NY
    Get tight heads or get yours cut to get more compression in th motor that made a big difference for me with my stock motor and with a 30 chopper 2 with 3 ppl and that stock 200 with a little compression i had no problem out of the hole... now My prop shaft was 2in above the pad and With a 34 et it would come out no problem with 2 ppl...I would put wedges on the transom cause I ain't have enough negative trim after 96-98mph but I would try putting a little compression in it
    Mirage RR
    Lake Tarpon Boyz!!!
    Jul 2008
    Key Largo, FL
    I have an 18 motion(action copy), for all around use , loaded down with passengers and cooler a 26 pitch big ear chopper works the best for me. One time I tried a raker and I had a lot of slip even while under way. I figured the prop shaft was probably just too high for the raker to hook up good so I just threw the chopper back on.
    86 18ft Motion (Action copy)
    98 Quartershot T-3
    Jul 2010
    miami fl 305
    Quote Originally Posted by DavidW View Post
    k thenks gona try geting a chopper
    Jul 2010
    miami fl 305
    it has a monty racing stamped on the back of the motor
    Sep 2002
    Merritt Island,Fl. Sunshine Syndicate Country!!!!
    post some pictures!! I have always used a 27 or 29 srx!
    Bobby Pazos- Member Of The
    BULL-FROG EYES DRAG RACE TEAM
    Fellow-G-Man,
    Sunshine Syndicate
    2006 23' Action Marine 300 HP V8
    2001 19' Action Marine White Power
    1998 23' Concept CC (sold)
    1999 17' Action Marine (sold)
    1996 STV River Rocket (sold)
    Jul 2010
    miami fl 305
    Jul 2010
    miami fl 305
    Jul 2010
    miami fl 305
    Jul 2008
    Key Largo, FL
    My best top speeds that I have seen I got with a 29srx but for carrying weight such as passengers and for geting up on plane the best all around performance for me has been with a big eared chopper.
    98 Quartershot T-3
  13. #13
    Jul 2008
    Key Largo, FL
    i just cant beat my chopper for gettin out of the hole or crusing with people and "stuff" in the boat.
    16.9 Action W/ 135
    17 Motion W/250 XS
    *Madness*
  14. #14
    Nov 2007
    I usually use a 26 et but for running long distance and top end I use a 34 et... but I also liked the 30 chopper 2 a lot for an all around prop
    Nice ride BTW always liked the red action s
    Mirage RR
    Lake Tarpon Boyz!!!
  15. #15
    Jul 2010
    miami fl 305
    how can make a merc or yamaha prop fit like a chopper with out rehubing thenks
