Results 1 to 3 of 3
Thread: 496 mercruiser
08-02-2010, 07:24 PM #1Junior Member
- Apr 2007
- 28
496 mercruiser
i have replaced the impeller in the raw waterpump and now the engine wont pump water.it was ok before i did this.it seems to be getting water all the way to the heat exchanger.when i pull the hoses from the exchanger to the exhaust manifolds it pumps water but as soon as i do the clamps up its stops.
any help or ideas would be much appreciated..
08-02-2010, 07:42 PM #2
Was the old impeller missing any blades? If so they are most likely stuck somewhere.
08-02-2010, 10:19 PM #3
Did you replace just the impeller or the whole kit? Did you use OEM parts?
