Results 1 to 3 of 3
08-01-2010, 02:35 AM #15000 RPM
- Jun 2009
- central minnesota
- 770
- 30
- 24
89 evin 115 ffi fuelrail pressure?
anyone have pressure number?---with key on pump runs 30sec,aprox,,rail pressure less than 20#.customers motor will only run 2-3 seconds.help-thanx th
08-01-2010, 01:57 PM #25000 RPM
- May 2006
- 400
- 17
Do you mean '98 not 89?
about 25 psi is average, it will run on 22 if everything else is OK. Are you priming the ball first before turning the key ON?
Does the pressure hold fairly constant after turning the key OFF, or does it instantly drop to about 10psi?
08-01-2010, 10:55 PM #35000 RPM
- Jun 2009
- central minnesota
- 770
- 30
- 24
my goof-98 for sure.priming first--never went over 18-20. will see w/key off. thanx--more info monday
