Results 1 to 12 of 12
07-29-2010, 04:50 PM #1
pump noise..............could it fool ya?
the pity party is over and i been messing around with the boat.gonna spin wrench's and see whats up.My new power seemed to be taking a quick toll on my pump and now the pump is full of noise at low idle and the bearing is rumbling loud. oil pressure has not changed and boat fires right up.
rolling along at 4000 rpms i thought i heard a noise and felt something going wrong so i let off. my passengers said whats up? i told them i thought i heard something. i slowly stepped up to 1500 rpms and it sounded like a wrist pin was letting go and i expected it to grenade pretty quick cause ive been there done that
we idled back and at the last i revved it and sure enough, big knock.
im gonna pull the engine, open and inspect,take pump apart, new bearings and whatever blah, re-assemble.
luckily im dumb enough to continue the stupidity.
07-29-2010, 06:03 PM #25000 RPM
- Jun 2009
- DFW
- 183
Have you stared the motor with the pump disconnected? It could be a pump or u-joint issue and nothing at all wrong with the motor.
07-29-2010, 06:12 PM #3
cut the oil filter open and inspect it for metal
7 to 3pm 5 days a week
Custom Fiberglass and Paint
In Business since 1984
for sale
07-29-2010, 06:21 PM #47000 RPM
- Apr 2008
- Washington N.C.
- 2,154
If a bearing goes out in the pump it will sound bad.
07-29-2010, 08:46 PM #5
will disconnect pump and run it tomorrow
07-30-2010, 03:22 AM #6
Come on Mike, tell us all ready.
Is it the pump or the motor.
My nerves are shot
Wikus
07-30-2010, 07:53 AM #7
i blew a pump and they do sound bad, thought the motor was comming apart, get it apart before any more damage is done
07-30-2010, 02:04 PM #8
well today i disconnected the drive line and ran the engine for a little bit. it seems like the motor is fine but i didnt run it long. will hook up water later today and run it a long time to see whats up. might not get to it till tomorrow.
07-30-2010, 04:14 PM #95000 RPM
- May 2009
- FL
- 345
well that is encouraging mike
07-30-2010, 04:33 PM #105000 RPM
- Jun 2009
- DFW
- 183
Did you spin the pump by hand? When the front bearing in mine went out it made a horrible noise even when turning it by hand.
07-30-2010, 07:39 PM #11
the bearing rumble constantly at idle but turns very free by hand
08-01-2010, 09:37 PM #12
I just replaced a motor in my boat and ran all day sat with it sounding good and never real got on it... but then today I started hearing some rattling noise and after inspecting it closer the noise is coming from the bell housing so either the u joints went south even though we inspected them after trowing everything back together or the pump bearing is fried but it turned freely buy hand and seemed to be solid. I hate having that bellhousing on there......now I have to disconect ever thing, pull the motor out and then pull the bell housing off to inspect further....this winter that 3 point mount is going in the trash
