Results 1 to 1 of 1
Thread: Olds 455 Compression Ratios
07-08-2010, 12:00 PM #1Junior Member
- Jun 2008
- Waucanda, IL
- 20
Can anyone tell me what CR they are currently running safely on 87 octane gas?
It seems most folks are running the 10:25 or 10:50 CR pistons but I would like to use a CR that I can comfortably run 87 octane since that is what most of the marinas sell and is most readily available.
I am planning to run the factory Ka heads at this time with the stainless Fel-Pro marine head gaskets.
I have a set of new L2390F low compression pistons from years ago- Would it make more sense to use these and shave the heads/block a little to get around 9 or 9.5 CR?
Please advise.
Thanks!
Elm
