Results 1 to 10 of 10
    May 2006
    leesburg , ga
    looper timing question
    having problems timing v6 225 , fresh motor just rebuilt , new pp and new stator. trying to set total advance at 16* and it will only get up to around 12-13 at 6000 rpm in gear in the water. the advance will not go any farther its not even touching the screw limiter the pointer is right at top dead center on number 1 the base just cant physically go any farther
    same with 2 different lights
    carbs are going to wot and the linkage arms arent limiting the advance
    any ideas
    May 2001
    Hickory NC
    Sounds like you have a flywheel or trigger problem assuming you have the correct timer pack combo
    May 2006
    leesburg , ga
    ok i checked on it today and fly wheel looks to be in good shape , magnets are all stuck good and are strong, none have moved. checked tdc and its dead on on #1 timer base is a 584586 and it should be good with the pp (586662) those same numbers were running together before a upper bearing melted everything.
    i found out today that the timing arm is hitting the forward stator bolt tower preventing it from going farther
    could ngk plugs be making it act funny
    or would you lean towards timer
    im working on another flywheel
    anyone got a timer for sale need a 584586 or anything compatable
    Mar 2003
    Arkansas
    What year is your motor? I have a 95 Evinrude Limited Edition 200hp PM me your number or I can PM you mine.
    In my 96 225 Johnson if I didn't run the Champion plugs it wouldn't run worth a darn and acted all funny. Not saying that is your problem but it could be.
    May 2006
    leesburg , ga
    Quote Originally Posted by 1badboat View Post
    dont know the year, its got all kinds off different parts but it is a fingerport block and it has the poppit in the block by the port head
    May 2001
    Hickory NC
    You need to look at the ctr hub not the outer magnets. The timer should not need to move any further
    May 2006
    leesburg , ga
    ok will check i was thinking that if it the piston was tdc and the tdc on the wheel lined up with the tdc mark on the pointer i was good but will check the hub
    May 2001
    Hickory NC
    I would also put timing marks for all 6 cylinders to check them. You are checking with the engine running at 5k under load correct?
    May 2006
    leesburg , ga
    will do, and yes in gear at the boat ramp on trailer prop about 90% in the water at 5000 or above gonna check it again tomorrow just to confirm my findings
    thanks for all the help
    May 2006
    leesburg , ga
    took it out this morning and it worked just like it was supposed to timied it at 16* i dont know what i was doing wrong but today it worked perfect only thing i did diff. was disconnect the quickstart wire, after it was warm
    its was a little hard to get started it will hit on one and disengage the starter over and over then all of the sudden be fine fire up and run
