Results 1 to 10 of 10
    Jun 2010
    Toronto Muskoka
    Question Power Steering turns left, but very hard to turn right?? Mercruiser
    Power Steering turns left, but very hard to turn right?? (at slow speeds, or not moving)
    I have the stock cable steering running into the mercruiser power steering unit.
    Installed a new cable, much better.
    Changed the valve on the power steering pump.
    Still, no luck.
    Any idea's??<!-- google_ad_section_end -->
    Jul 2008
    severn bridge
    is the cable routed with free play to move and actually operate the valve properly!
    Jun 2010
    Toronto Muskoka
    Quote Originally Posted by donmac View Post
    Not sure what you mean? The cable when NOT connected to the power steering unit, works fine, very smooth. But once connected bery hard to turn
    Boca Raton, FLORIDA
    Same answer as already posted on the other site, it is the valve(steering unit).
    Apr 2010
    Bristol RI
    It is a power steering rack ballancing issue. The older ones are adjustable, the newer ones you can't adjust. Does it want to turn by itself and are you constantly correcting it? Either way it sounds like the rack needs to be replaced.
    Boca Raton, FLORIDA
    NOT the rack(bben there, tried that), it is the Brazil vave(or Saginaw valve) on the transom.
    Sep 2007
    new york
    as Donmac stated it sounds like the cable routing. The cable it self has to be able to move freely. The valve is actually activated by the whole cable moving on the actuator, then the core of the cable moves the drive. It only move about 1/2" each way. Have some one turn the wheel while you look at the cable movement on the actuator
    Apr 2010
    Bristol RI
    If you got a book and followed the trouble shooting directions which are straight forward, you would be able to figure it out. It sounds like the control valve in the power steering rack. disconnect the cable as it exits the rack (clevis pin) hook up a power steering pressure tester between the pump and the rack. Manually pull and push the cable where it goes into the rack and note the results, the pressure should spike as you do it, If it doesn't for pulling but does for pushing, or vice verse then it is the control valve inside of the steering rack and the assembly needs to be replaced as a whole unit. Mercruiser P/N 806034A 1
    Jun 2010
    Toronto Muskoka
    Thanks for all the replies, sounds like it is the power steering rack.
    Will let you know once I've replaced that to see if that is it.
    Thanks again.
    P.S. Anyone in Ontario Canada know who might have a used one??
    Jul 2008
    severn bridge
    Quote Originally Posted by 2SlowinTO View Post
    Thanks again.
    McGregor Marine should have some,they usually come up with anything I need!
