Results 16 to 29 of 29
Thread: new guy here first jet boat.
06-23-2010, 12:38 PM #16
awesome! I just hate the fact that you can not get a place diverter for it. I would love to throw a big roost!!!
06-23-2010, 12:43 PM #17
62 mph at 4400 rpms sure sounds nice
06-23-2010, 12:44 PM #18
Yea that would be nice, but you can do something other jet boats can't do.
It is called the "Hamilton Turn"
You can do a 360 degree turn while underway and keep going
You can also do a full on emergency stop. (But be carefull with this one)
Wikus
06-23-2010, 12:47 PM #19
06-23-2010, 03:34 PM #20
06-24-2010, 05:56 AM #215000 RPM
- Jul 2006
- Walled Lake, MI
- 928
Great looking boat, any more pictures?
06-24-2010, 06:19 AM #22
I hope to get some this weekend.
06-24-2010, 09:31 AM #235000 RPM
- Jan 2006
- macon GA
- 824
So you got it from Tim ?
Have known him for 19 years,he knows jet pumps.
06-24-2010, 09:49 AM #24
yeah. Tim knows his stuff. He is a real nice guy and will tell you anything you want to know.
06-25-2010, 08:31 AM #25
Well it looks like the time for a motor came sooner than later. It sucked a head gasket last night. I could be mad but that will not help any so I started looking for a motor and found a BBC this morning. Hoping I can go pick it up sunday.
06-25-2010, 11:30 AM #26
Check the water pressure from the pump to the motor. The 773 should have 2 feeds from the pump to the motor. They are prone to pump high psi numbers. A pressure relief valve is a good idea on them. It also depends on how your water is fed to the motor.
If it is through the headers then to the engine it shouldn't be a problem. If it is directly from the pump to the block a relief valve would be recommended.
Wikus
06-25-2010, 11:40 AM #27
I will look tonight. I found a smoking deal on a freshly rebuilt bbc and a set of over the transom wet headers so it looks like I am going to jump on that anyways...
06-26-2010, 08:50 PM #28Junior Member
- Nov 2007
Cool boat, Kodiak and Scott parts are both available here in the states from the NW.
Scott does make a trim nozzel for the hamiltom pump, not sure it has the preasure to shoot the huge rooster of the berks and AT's.
These guys can help you with what 3 impellers you need for a given HP and desired effect.
Here are a couple of links:
http://kemequipment.com/kodiakmarine.html
http://www.schlagelmarine.com/Distributors.html
06-27-2010, 11:39 AM #29
Thanks! I'll check out the links. I'm pulling the motor now and supposed to pu the bb on wed I hope to be back on the lake next weekend.
