Results 1 to 4 of 4
Thread: Cliking noise
    Sep 2009
    Cliking noise
    The boat ran great all last weekend at the river (Buckskin Park) First time on the river with this boat. In rough water I trimmed the place diverter all the way up and nailed it and the hull setteld in and ran perfect. Nice and stable. On the last day and now in the garage I here I loud clicking when I turn the key to start it. It turns over with the clicking sound. Any info would be greatly appriciated.
    Jan 2008
    Southern Illinois
    You need to try a locate where the noise is coming from. Can you hear it while it's running or just while the starter is cranking? Does it sound like the front of the motor.back of the motor, or jetdrive? Here is a couple of things to check at this point. Loose or cracked flywheel. Loose bolts on drive shaft or bad U joints.
    Northern ILL.
    is it the starter sonenoid chattering? does it do it once running?
    UMPBA 926 Gas Jet
    Sep 2009
    Sounds like the solenoid is chattering.
