Results 1 to 15 of 17
Thread: Fuel pump for Mercury EFI 260HP
06-01-2010, 11:02 PM #1Junior Member
- Jun 2008
- Dorado, Puerto Rico
- 25
Will this pump do the work????
http://cgi.ebay.com/ebaymotors/ws/eB...i%3D1&viewitem
Thanks!!!
Hiram
06-02-2010, 09:24 AM #2
Need to know the pump output pressure. I'm sure the pump will support the volume but you need a minimum output pressure capability of around 90-110 PSI to the regulator. A 260 needs 39-41 psi at the rail and the Drag style and later ECU's require 56 psi. (black regulator)
06-02-2010, 10:24 AM #3Member
- Jun 2009
- OK
- 75
Is that 39-41 psi when the engine is running? Mine is set at 40 psi when the pump is on and the engine is off, but the pressure drops about 4-5 psi when the engine is running.
06-02-2010, 11:48 AM #4Markus' Performance Boating Links:
06-02-2010, 02:41 PM #5Junior Member
- Jun 2008
- 25
The fuel pump specs are the following:
-10 Inlet and -10 Outlet
Flow: 135 GPH
Pressure: 0-95 psi
Thanks!!!
Hiram
06-02-2010, 07:01 PM #6
I run a Bosch 984 on both my 260's , one with a 39 lb system and 1 with a 56 lb system . Double filter in front of the pump ......wire them with 10 gauge wire and a 25 or 30 amp breaker or fuse . Very reliable for years now ...mount it as low in the boat as you can .
06-02-2010, 07:40 PM #7Junior Member
- Jun 2008
- 25
Thanks for the advice Tom.
Nice to see you here and also at Jim's Boat Dock!!!
Hiram
06-03-2010, 12:41 AM #8Junior Member
- Jun 2008
- 25
06-03-2010, 06:17 AM #9
Tom nailed it. For the cost of that weldon on E-bay you can buy a Bosch 984 from Brucato a mounting bracket & hose adapter with some serious beer money left over. And you're buying from a supporting vendor.
06-29-2010, 07:12 PM #10Junior Member
- Jun 2008
- 25
Thanks to all for your feedback!!!!!!
Hiram
06-29-2010, 07:12 PM #11Junior Member
- Jun 2008
- 25
Which pressure regulator is recommended for the Bosch 984 fuel pump??
Thanks!!!
Hiram
06-30-2010, 05:18 AM #12
I use an aeromotive as does alot of others. You'll need to make sure you get a high pressure one. This is the one I use and i fabricated a special mounting bracket.
Aeromotive 13109 - Aeromotive A1000-6 Injected Bypass Regulators
<FIELDSET class=item-disclose><LEGEND>View Image and Compare</LEGEND>
- <INPUT id=compareCheck_AEI-13109 onclick="javascript:compare( 'AEI-13109', 'toggle', this );" type=checkbox name=Compare><LABEL style="DISPLAY: inline" id=labelText_AEI-13109 for=compareCheck_AEI-13109>Compare</LABEL>
Fuel Pressure Regulator, 30-70 psi, Clear and Red Anodized, Universal, Each
Part Number: AEI-13109
Estimated Ship Date: Today
<FIELDSET class=user-actions><LEGEND>Transaction</LEGEND>
- $139.95
Capt.Insane-o liked this post
06-30-2010, 10:33 AM #13Junior Member
- Jun 2008
- 25
06-30-2010, 03:29 PM #142006 Spectre 24' SCS
2020 Mercury 300 ProXS
2001 Allison XB2003
2006 Mercury 250XS
1988 22' Velocity (sold)
1995 Allison Grand Sport (sold)
1998 Mercury Stock 2.5-260 SS
1990 Velocity 30' - 502's (sold)
Go Daddy Go! Racing
06-30-2010, 04:17 PM #15
