Results 16 to 18 of 18
Thread: props and fuel economy
08-24-2018, 11:12 PM #16
Ya mine has a pad so once up on that theirs very little drag and the motor doesn't work hard at 65-70 and with a big wheel sips fuel. Lower speeds with lots of hull in the water burns more fuel.
08-31-2018, 12:38 AM #17
I agree, my boat at least w my chopper runs effiently at a 25-30 mph range on plane just as he says. Also, the other speed it gets the best mileage / bang for the buck is about 58-63 mph ....packing air under boat at a cruise of 4800 -5200 rpm with some positive trim and Jack plae fairly high ......it's significantly better mpg than almost any other speed other than really slow. It's happy ....not working hard and not a lot of wetted surface , very controllable and fun ! I looked at boat test in magazines on similar efficient Hulls and it's usually consistent with my findings. I agree with not "lugging" I also think that hurts mileage. There are a ton of variables but that's my .02 cents
Scott Strang
Present:
1987 Hydrostream Vegas XT
175 HP Yamaha Pro V
225HP Yamaha 2.6 (Just Bought, can't wait to put together and run! )
Past
1987 Valero YT Bowrider
1994 Pro V 175 Yamaha
Recently deceased:
19 foot Action Marine
225 Evinrude Vindicator
245 HP Carb 2.5 Merc
1984 Hydrostream Vector
2.4 Merc Bridgeport Carb
09-03-2018, 02:41 PM #185000 RPM
- May 2004
- Washington, Missouri
- 329
I can only speak from my experience, running a thirsty v8 outboard, I've found that putting my boat on the pad, like other's have already stated, then backing the throttle off to just where the maximum timing advance happens... on my engine, that's 5000 rpm.
I run a 32 cleaver doing this and it puts me just under the 73mph mark, which is where **** gets real and you have to actually pay attention and drive the boat... With this method, I'm getting just under 3mpg, which from what I understand is exceptional for a v8 looper.
I would assume that most others would find similar results... Most of the time MPG in anything has more to do with the driver than the setup.
