Results 1 to 6 of 6
Thread: oil block off plug- which way?
05-25-2010, 07:29 PM #1New Member
- May 2010
- Cape Cod
Switching to premix- question, the block off plug-does the flat side face right or left as you insert it? It fits both ways but I am sure there is a correct way!
Mercury 2.5 [M2]
05-25-2010, 08:57 PM #2
check the 2 bolt holes thru the plug and how they line up to the holes in the block - i think they're spaced differently from the centre so you cant put it on wrong
05-26-2010, 11:47 PM #3
Yup, the bolt holes only line up one way and the flat goes toward the crank
Kaase Outboard Hydro/Bottle Fed 300 Drag
05-27-2010, 05:26 AM #4
05-28-2010, 06:39 AM #5New Member
- May 2010
- Cape Cod
I thank you all- Didn't want to try starting it and have plastic get into the motor if I put the plug in backwards!
05-28-2010, 09:50 AM #6
He who has the most wisdom is the one who asks questions --- make well planned mistakes only when necessary
Steve Schefer
