Results 1 to 15 of 46
Thread: New Transom Knees for AE-21
05-19-2010, 05:16 PM #1
Now that I've got my AE-21 transom cleaned and prepped for glasswork, it's time to begin building the transom knees. I made a cardboard template yesterday morning by crawling inside the bilge. I cut two new transom knees out of 1.5" thick 24lb density Airex PXC (Penske board). Each knee will receive two layers of 1708 glass before I bond them to the floor/transom/topdeck. I'm going to use West Systems Epoxy for the resin.
J-Town Hot Boat Team
Barracuda 188CCR/Suzuki 140
Past Boats:
Checkmate 2800SX/Twin Merc 250’s
Checkmate Pulsare 2400/Verado 300
Checkmate Starflite/Merc Pro XB250
Canadian Edition Hydrostream AE-21/Merc 2.5
Checkmate Pulsare 2100/Merc 225Xri
Hydrostream Valero YT Bowrider/Merc 175
Talon T-21/Mercury Racing 2.5 Carb
Sleekcraft ModVP Bowrider/Evinrude 225 Vindicator
Velocity 230/Mercury 454 Magnum
Scout 172 Sportfish/Yamaha 130
SeaRay F16 Jet boat/Mercury SportJet
SeaRay 17' Seville/Merc I/O
05-22-2010, 04:12 PM #2
Hey guy , how are things going ?
05-25-2010, 11:24 AM #3J-Town Hot Boat Team
Past Boats:
05-25-2010, 01:32 PM #4Member
- Jun 2007
- crescent city fl
- 43
I have seen this brought up quite a bit. It is my understanding that the 1708 is fine to use with epoxy as the mat does not contain binders, instead it relies on the stitching to hold it together. That being said the additional mat will not add any significant strength over plain 1700 only help to build thickness. I've used 1708 on the bottoms of several hard use flats boats to add some abrasion resistance and I have never had a problem. I am hesitant to reply to these types of things as I have seen what happens with some of these threads. This is my opinion based on my experience.
05-25-2010, 03:18 PM #5
Hey guy not trying to be rude or tell you what you to use but i have worked at two different boat Co,s that use Epoxy in there build and have seen 1708 fail when used with Epoxy either in high speed applications or cruiser style boat's such as Tiara or S 2 YACHTS as there are often called and i think if you use a fabric with a no chop back you will find that you will be able to keep the cost down in the resin Dept because the chop backed fabric such as 1708 takes a bit morer resin to wet out AND 1700 Bia , S or E glass are great fabrics to use with Epoxy and designed for that type of resin and like i said its your call and i have been using epoxy for over 38 years now and is the only resin that i will ever use for any type of repairs .
05-25-2010, 03:29 PM #6> Stainless steel Merc cowling plates - $110 shipped TYD - LINK <
05-25-2010, 05:19 PM #7
Hey JP hows it goin.
If I were you I would pull some of the floor and tie the knees into the stringers and then put the floor back.
05-25-2010, 08:36 PM #85000 RPM
- Dec 2003
- NJ
- 254
Look into Mas Epoxy They have a thiner epoxy that works very well. I am redoing a boat with it and yes the 1708 does take more to wet out. Don't skimp. It is also a non blush epoxy. I have used west and others but like the Mas and they are good to deal with. Check them out on the web.
05-26-2010, 09:47 AM #9J-Town Hot Boat Team
Past Boats:
05-26-2010, 10:49 AM #10
Personally, I would go with 1708, and Vinyl Ester, but thats just me.
05-26-2010, 12:15 PM #11
use Cheese cloth and liquid nails, works great everytime!
Don't lick my boat, It makes it sticky!
Another Hitman for the Sunshine Syndicate!!
2011 Seafox Viper
05-26-2010, 12:48 PM #12
I'm getting advice from Polymeric Products in WPB. They are a specialty FibreGlass shop that builds boats, molds, race car fairings, motorcycle fairings, ground effect kits, custom work, surfboards..etc. He's the guy that built the mold for the 41' Apache that is now at the Pantera factory..The owner "Jed" has been working with fibreglass, resins, cores, kevlar, etc for over 45 years. He's kind of like a mad scientist who speaks way over my head...compression ratiios, molecule flex failures, chemical bonding aspects, core shear,...the guys written an entire chapter on the elements of surfboard design, hydrodynamics, lift and foil...etc. As soon as I get some spare time, I'll run by his factory and confirm the dynamics of using 1708 biaxial glass with epoxy resin...
Past Boats:
05-26-2010, 12:54 PM #13
that sounds like to much work, take my word for it, cheese cloth and liquid nail, or super glue.....
or anything my 5 year old is playing with...... I don't know how he does it, but everything is sticky and what ever it is, its hard to remove...Don't lick my boat, It makes it sticky!
2011 Seafox Viper
05-26-2010, 05:05 PM #14
05-26-2010, 09:19 PM #15
OK that sound better than what I thought you were doing by looking at the first picture. I still think I would opt for tying in to the outside of the stringers. The stringers are the backbone of the boat, if the engine tries to flex the transom and the transom is tied with knees to the stringers instead of the transom flexing the bow just goes up. That is what you want your transom tied into via the knees.
