Page 62 of 62 FirstFirst ... 12 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
Results 916 to 923 of 923
  1. #916
    Houston, TX
    Quote Originally Posted by papasap View Post
    Can some one please tell me the correct height your motor should be mounted on 22 velocity , with no jackplate
    welcome to scream and fly. From 1-2” below pad but I’m sure others will chime in.
  2. #917
    Jan 2012
    miami
    Are you referring to the cavitation plate being 1-2 inch or the prop shaft?
  3. #918
    ...propshaft...
  4. #919
    Suffern, NY
    ...propshaft...
    There are many variables. The higher the power to weight ratio the higher you can go. Then you have to consider water. Some boats run higher than a low water pick up can deliver. Thats why I suggested earlier to post a picture of your setup. No one can accurately answer your question without a little more info.
  5. #920
    Jan 2023
    Tacoma wa
ID:	527382Should be finished by the end of the month. Can’t wait to do some testing with this motor setup.
  6. #921
    Jan 2023
    Tacoma wa
  7. Likes V pads liked this post
  8. #922
    Dec 2019
    Spring Lake MI
    Lower unit work on the SHO? Tune? Should be fun I love the all white 22!!!
    TJ @ Baker Engineering
    Tuff 24 300xs
    Tuff 16 90 Yammie
    3.75@199mph with LSX power!!!
  9. #923
    Jan 2023
    Tacoma wa
    I plan on doing those mods eventually but I’m going to run it stock for a while.
