Results 106 to 120 of 180
06-21-2004, 04:56 PM #106
GREAT thread TTT for the people that havent seen this!
06-21-2004, 08:55 PM #107
merc
mine are already drilled from the factory 5, 1/2 in holes on each side the motors are obnoxious at cruising speed you can hear them for miles yet register 84 db at idle. your method sounds great but i'm not going to cut pieces off the mid. cool job tho.
06-21-2004, 09:29 PM #1085000 RPM
- Apr 2004
- ft worth tx
- 236
omc guys
on my ole 200 i cut the ENTIRE exh out of the lower,it was awesome souding but the lake patrol didnt think so,so when i knew or saw them on the lake i would idle over to the beach and pull out the trusty pieces aluminum i had ball peeed to fit the angle of the lower unit with a screw and wingnut(nylock) and just QUICKLY install them and whalla,no more noise,cheap set that cost bout 1.00.......than when they went back wherever they cane from tilt the moter up and pull it back off .....bythe way i,m talikn exh cavity area on the lower unit only
06-22-2004, 11:49 AM #109
wow, posted this 2 years ago roughly, sure feels longer than that
07-19-2004, 02:08 PM #110Junior Member
- Jul 2004
- cedar rapids ia
- 18
EXHAUST ENHANCING
I AM NEW TO THE BOARD
I HAVE A 1998 MERC 3.0L 200 HP
IM LOOKING AT THE POST WOULDN'T ONE JUST BE ABLE TO DRILL SOM 1/2 " HOLES UP FROM THE BOTTOM AND CALL IT GOOD FOR A LITTLE LOUDER EXHAUST TONE. LIKE SOME OF THE ONES THAT DID IT FROM BEHIND. IT WOULD BE LESS NOTICEABLE FROM UNDER NEITH AT IDLE AND LOUD ON PLANE
CORRECT?? DOES THIS HELP OR HINDER PERFORMANCE AT ALL?Last edited by SHEP358; 07-19-2004 at 04:55 PM.
07-19-2004, 09:40 PM #111Guest
- Apr 2003
- Michigan
- 543
SHEP358...
Sorry, you can't drill up from the bottom without drilling thru the cav plate too (not a good idea)... plus, you need to remove the inter liner (can) so that the newly drilled exhaust holes have a purpose! A good time to install solid mounts as well...
To take advantage of the relived exhaust mod, you need to do other perf. work (heads milled, velocity stacks, reeds, rejetting, etc.) to gain any noticable horsepower or RPM... otherwise it's just noise. Jim.
11-07-2005, 02:20 AM #112
Back To The Top... Been A While
03-28-2006, 02:17 PM #1135000 RPM
- May 2001
- 404
BUMP So I can find it...
06-23-2006, 07:50 PM #114
I'm going to need this tomorrow, so I'm bringing it to the surface
I would like to express my thanks to Talon2.5 for the great step by step, complete with photos even!
YOU THE MAN!!
06-25-2006, 09:45 AM #115
Talon,
Did that to mine. SOUNDS SO SWEET! Thanks!!!James Perry
06-29-2006, 12:19 PM #116
ttttt
06-29-2006, 02:42 PM #117
Skip, been 4 years now, is that long enough?
IMHO, this sounds just as good if not better than the OS dump. Ive done it to two motors so far.> Stainless steel Merc cowling plates - $110 shipped TYD - LINK <
06-29-2006, 08:06 PM #118
It's louder than an offshore dump, that's for sure. Just ask the author of this thread. Side by side, his 2.5 offshore dump, next to my 2.4 with the mid seen here in this thread. He could here mine over his.
--Brian Chandler--
Sunshine Syndicate Wiseguy.
06-29-2006, 09:05 PM #119
i think from behind the OSD is louder, but from the front possibly the modded one. maybe due to the way the exhaust echos down off the water? also, the pitch of the OSD is deeper, making it not sound as loud. both sound badass though.
12-13-2006, 10:31 AM #120Member
- Sep 2006
- 64
Can this mod be done with the motor on the boat or do you have to pull it off the boat to tear it down.
Is there any gains besides the noise
